throttle problems - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 40 (permalink) Old 04-23-2007, 06:09 AM Thread Starter
throttle problems
i have an 05 zx-6r....12,900...love it...i got it a 8,500 miles and rode it for a while and then it started running funny....through all gear and idling,the thorttle works through 75% normaly and the rest of the throttle it acts like it chokes itself....like if u floor it it jumps up to 13 then it drops to 6 then goes up to 9 and then down to 5...and idk how to fix it...so can any help me...
SMFB636 is offline
post #2 of 40 (permalink) Old 04-23-2007, 09:38 AM
Maybe the carbs need to be cleaned?
Bad gas?
Clogged fuel filter?
Fouled plugs?
I would take off the tank... replace the fuel filter, replace the plugs, drain the gas and check the carb operation when you're under there.
Where at in Michigan are you?
post #3 of 40 (permalink) Old 04-23-2007, 09:40 AM
no carbs, FI
post #4 of 40 (permalink) Old 04-23-2007, 09:43 AM
Bad gas?
Fouled plugs?
Completely drain your fuel system. Check for clogs.
post #5 of 40 (permalink) Old 04-23-2007, 10:00 AM
no carbs, FI
Yeah ok... then check the throttle bodies and injectors for operation...
post #6 of 40 (permalink) Old 04-23-2007, 11:17 AM
Water in gas.....drain Mr. Gas tank.
oldetymebiker is offline
post #7 of 40 (permalink) Old 04-23-2007, 03:26 PM
post #8 of 40 (permalink) Old 04-25-2007, 10:05 AM
Yeah that's why I said... attack the fuel system.
post #9 of 40 (permalink) Old 04-27-2007, 06:35 PM Thread Starter
ok..but this is like the 8th set of plugs i've put in it....i found a fuel line kinked a little bit and used a new hose and it didnt fix it....and everytime i run fuel injector cleaner or gas treatment it only makes it worse for tht tank of gas
SMFB636 is offline
post #10 of 40 (permalink) Old 04-27-2007, 09:52 PM
have you tried gas dryer?
try sea foam to clean your system... it's always helped me...
post #11 of 40 (permalink) Old 04-29-2007, 08:32 PM
Check your vacuum lines. They may have a very small leak.
jnn7404 is offline
post #12 of 40 (permalink) Old 04-29-2007, 08:33 PM
BTW great choice on your bike!
jnn7404 is offline
post #13 of 40 (permalink) Old 05-18-2007, 03:32 AM Thread Starter
whats sea foam..i never heard of tht stuff....i always run premium and once it warms up and run it full throttle for a lil bit its picks up a lil speed but not much..so idk
SMFB636 is offline
post #14 of 40 (permalink) Old 05-18-2007, 08:53 AM
Kinda sounds like what was happening to my bike before the clutch went out. I dunno, my RPM's were jumping then lagging, as if the bike was getting no throttle. I rode the bike 50 more miles to the point where it got throttle up to 8k rpms in 3rd gear and wouldn't go over 70 mph. Then it stopped going over 17 mph. Just something to look at, I dunno though. It sounds like a fuel problem but so did mine at first. Maybe it's because of the RPM jump, and seemingly loss of fuel flow to the engine. I guess you'll find out if you keep riding it and the clutch stops working.
BarryP is offline
post #15 of 40 (permalink) Old 05-19-2007, 09:08 PM Thread Starter
well i've ridin it for about a thousand miles...and it does it standing still...through all 6 gears.......where would i be able to get sea foam and how much is it???
SMFB636 is offline
post #16 of 40 (permalink) Old 05-20-2007, 10:26 AM
autozone carries it, and its like <$9 a can.
post #17 of 40 (permalink) Old 05-20-2007, 03:47 PM
If the sea foam doesn't fix it your clutch is shot. Mine did it standing still and in all 6 gears. Put the bike in gear, turn it off and try pushing it forward after its warmed up. If it moves you have the same problem I did.
BarryP is offline
post #18 of 40 (permalink) Old 05-23-2007, 01:11 AM Thread Starter
well i did it and its just fine....stops like right away..and i tried pushing it hard and it doesnt slip
SMFB636 is offline
post #19 of 40 (permalink) Old 05-23-2007, 07:40 AM
Maybe it's not completely shot yet. Maybe it's not even the clutch, but the problem sounds the same as mine.
BarryP is offline
post #20 of 40 (permalink) Old 05-23-2007, 10:41 AM
i would take it to a dealership. they will pull the codes from the ECU.
