Whats wrong with my 636? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 16 (permalink) Old 04-26-2007, 01:01 AM Thread Starter
My bike is'nt starting like it used to. Before it started on the first turn over, but now it takes longer and longer, i replaced the battery but that did'nt help.The bike is three years old.
F1R3 57ORM is offline
post #2 of 16 (permalink) Old 04-26-2007, 05:28 AM Thread Starter
my 636 is having trouble starting.
it just wont start like it used to. it used to fire on the first turn over but now it takes longer and longer. i changed the battery but it still does it?
post #3 of 16 (permalink) Old 04-26-2007, 05:30 AM
Check your plugs.
post #4 of 16 (permalink) Old 04-26-2007, 05:32 AM Thread Starter
is there an easy way to get at them?
post #5 of 16 (permalink) Old 04-26-2007, 05:35 AM
You'll have to pull the tank. It's not hard. Should just be a couple bolts holding it on. Do you have a repair manual?
post #6 of 16 (permalink) Old 04-26-2007, 05:58 AM Thread Starter
all i have is the stock manual it sucks, i've had the tank off plenty but not the air box wich covers the plugs i've never really taken it apart past there. how long do plugs usually last? and what do you think it cost me for a complete tune up?
post #7 of 16 (permalink) Old 04-26-2007, 06:05 AM
I replace my plugs every year. I run NGK's...and get them at about $9 bucks each. Tune up will cost you a few bucks...but it's a necessary evil.
Look on eBay for a service manual for your bike. It'll really help...it explains all that stuff.
post #8 of 16 (permalink) Old 04-26-2007, 06:18 AM Thread Starter
yeah it's definatly time for new plugs mine are 3 years old, i'll change them asap. what do they usually do in terms of a tune up at a bike shop. do you do your own or take it in.
post #9 of 16 (permalink) Old 04-26-2007, 06:32 AM
I like to do most of my own work. Unless its outta my league. But I do simple stuff...oil, plugs, etc.
Tune up could be talking about a number of things....plugs, air filter, wires, fuel filter, etc.
You could also go a step further and swap out the fork oil and seals too. As well as checking valves, changing your coolant, etc.
post #10 of 16 (permalink) Old 04-26-2007, 06:47 AM Thread Starter
yeah i do mostly all my own work except for tire changes and anything that deals with tearing the engine apart. thanks for all the info.
post #11 of 16 (permalink) Old 04-26-2007, 09:21 AM
Year
Make
Model
What does it sound like?
New plugs?
Bad gas?
What did you do or not do to it for winterizing?
post #12 of 16 (permalink) Old 04-26-2007, 09:27 AM
Merged the 2 threads....
post #13 of 16 (permalink) Old 04-26-2007, 03:03 PM
I erringly got an '03 service manual at home that won't work for me. If I haven't given it away at another forum then I'll send the stuff to you. Drop me a PM with contact info and I'll get back to you when I can.
kanwisch is offline
post #14 of 16 (permalink) Old 04-27-2007, 12:40 AM
if he doesnt want it, send it this way...
post #15 of 16 (permalink) Old 04-28-2007, 09:10 PM
My bad, the manual is for '00-'02, sorry.
kanwisch is offline
post #16 of 16 (permalink) Old 04-29-2007, 09:47 PM
Plugs are simple. I have a 00 zx6r but they should be really similar. 4 10mm bolts on the tank 2 in front and 2 on rear under driver's seat. unhook the gas line and remove the tank. The airbox has 2 holes on the top with a rubber plug in them. Remove the plugs and there is 2 10mm bolts in there. Remove them and the 6 other 10mm's around the box. The box then pulls straight up and back. Then there will be some vacuum lines in the way, label them with a white out pen then remove them. You should then see your sparkplug coils and harnesses. Remove the harnesses and pull the coil and wallah there is the plugs. Like I said it should be very similar so good luck.
I buy my plugs at advance auto they are ngk cr9 and they are $3.50 each.
Download the free manual on the sticky thread from the technical help forums. It takes a long time to download but definatly worth it!
jnn7404 is offline
