tire pressure? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 37 (permalink) Old 05-03-2007, 11:11 PM Thread Starter
tire pressure?
hey fellas,
anybody know where i can find out where to get recommended
tire pressures for my bike?
stupid question but, should i follow the pressures that are listed on
the frame tag that lists manufacture date, etc....?
the tag lists 36psi F, and 41psi R cold. does that sound about right?
TIA
post #2 of 37 (permalink) Old 05-03-2007, 11:15 PM
That sounds about right. I know I ALWAYS run 2# lower on all of my bikes. It just gives a bit more cush for street riding.
post #3 of 37 (permalink) Old 05-04-2007, 06:30 AM
If you have after market tires..which you probly do...get ahold of the tire manufacturer...they will give you a recommended pressure for your ride.
post #4 of 37 (permalink) Old 05-04-2007, 07:06 AM
I would recommend putting in what the manufacterers ask. You can always adjust a +/- a few lbs. without any issues.
1quick1 is offline
post #5 of 37 (permalink) Old 05-04-2007, 07:15 AM
Although if you've gone to a wider tire or taller tire those numbers aren't right on.
post #6 of 37 (permalink) Old 05-04-2007, 07:17 AM
That is also true. I think most tires have the recommended PSI right on them if I'm not mistaken.
1quick1 is offline
post #7 of 37 (permalink) Old 05-04-2007, 07:18 AM
The PSI marked on the tire itself is maximum pressure.
post #8 of 37 (permalink) Old 05-04-2007, 07:23 AM
Yea that is correct.
I have 42psi on both of mine right now but it's hard to keep them consistent this time of year with the 20-30 degree temp changes throughout the day/night.
1quick1 is offline
post #9 of 37 (permalink) Old 05-04-2007, 07:25 AM
That seems like a hell of a lot of air mang.
post #10 of 37 (permalink) Old 05-04-2007, 07:43 AM
42 is what was in my rear tire when I bought my bike. It has since dropped to 36 through frequent pressure checks but the dealer filled mine with nitrogen so the tire pressure is always consistent.
post #11 of 37 (permalink) Old 05-04-2007, 07:49 AM
I'm running 37 front and back right now...Pilot Powers.
post #12 of 37 (permalink) Old 05-04-2007, 08:01 AM
PP's go on today.
post #13 of 37 (permalink) Old 05-04-2007, 08:06 AM
Originally Posted by Rider View Post
PP's go on today.
Nice man. Nice. You gonna get to go on a nice scrub in ride?
post #14 of 37 (permalink) Old 05-04-2007, 08:09 AM
Hell yes. Might not be able to scrub the strips off completly today, might get close though. Maybe on Saturday when I have more time.
post #15 of 37 (permalink) Old 05-04-2007, 08:11 AM
Nice. I think I put about 75 or 80 miles on the initial ride. Strips were down to about 1/4 inch. They stick almost right away.
post #16 of 37 (permalink) Old 05-04-2007, 08:19 AM
R1HOOLIGAN's Avatar
Never exceed what's on the frame sticker. Every bike I ever had stated 36 front, 42 rear. I usually run 34 front, 40 rear. Too low will eat up your tire, too high will eat up the center and not handle very well.
R1HOOLIGAN is offline
post #17 of 37 (permalink) Old 05-04-2007, 08:20 AM
Stunt4Life's Avatar
I run 31 32 on mine
Stunt4Life is offline
post #18 of 37 (permalink) Old 05-04-2007, 08:26 AM
Originally Posted by Stunt4Life View Post
I run 31 32 on mine
What tires you running?
post #19 of 37 (permalink) Old 05-05-2007, 08:56 AM Thread Starter
thanks guys, and everyone else.
i pretty much just followed what was on the frame sticker
36psi F, 41psi R cold.
since the tire sizes were same as OEM specs.
post #20 of 37 (permalink) Old 05-05-2007, 12:46 PM
you can try nitrogen instead... it'll keep the tire pressure consistant longer than plain air.
