can it be the battery? my fan didn't come on! - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 29 (permalink) Old 05-04-2007, 07:56 PM Thread Starter
richrom2's Avatar
i was riding today and got stuck in traffic. i noticed that my temp gauge was rising and the fan wasnt coming on. i dont know how long its been going on for. can it be the battery not having enought juice to power it?
2003 mercedes clk55, 2005 lincoln aviator
richrom2 is offline
post #2 of 29 (permalink) Old 05-04-2007, 08:05 PM
If it has juice to run the lights, it can run the fan.
Check your coolant level and make sure there is nothing blocking your fan. mine comes on at 220F.
Check those for starters.
777Customs is offline
post #3 of 29 (permalink) Old 05-04-2007, 08:58 PM Thread Starter
richrom2's Avatar
how would go about checking coolant level?
richrom2 is offline
post #4 of 29 (permalink) Old 05-04-2007, 09:24 PM
Check owners manual or service manual.
I think that on yours (if similar to the honda) has a radiator cap on the side of the radiator behind the side fairing. And also an overflow bottle on the front or side of the engine also behind the fairing. Usually on the same side.
post #5 of 29 (permalink) Old 05-05-2007, 02:58 PM Thread Starter
richrom2's Avatar
see when im riding and come to a light i notice that the instument lighting is dim until i rev it or start moving. at times my horn wont work i guess because the battery is low
richrom2 is offline
post #6 of 29 (permalink) Old 05-05-2007, 06:27 PM
Check your charging system.
Check this thread.
https://www.twowheelforum.com/showthread.php?t=17368
post #7 of 29 (permalink) Old 05-05-2007, 10:19 PM
Yeah one thing at a time.
Check your battery. With bike off and sitting. Should show about 12.9 volts. If not your battery could be low.
What temp did the bike get to? Most fans don't kick on till 215-220 degrees. That is normal.
post #8 of 29 (permalink) Old 05-05-2007, 10:20 PM
Also I moved your thread to tech.
post #9 of 29 (permalink) Old 05-06-2007, 02:58 AM Thread Starter
richrom2's Avatar
my bike is in celcius. it got to 100. now when i rev the bike i see that the fan moves a tiny bit
also when my horn feels like working my cluster goes dim when i blow the horn
richrom2 is offline
post #10 of 29 (permalink) Old 05-06-2007, 04:27 AM
if you want a cheap solution.
put a switch in your handle bar direct to the fan.
luis is offline
post #11 of 29 (permalink) Old 05-06-2007, 11:39 AM
My buddy did that and it works great especially in traffic or slow riding. If you do this i highly suggest a heavy gauge wire.
But still try to find out why it's doing this. It didn't quit working for no reason. Check your altenator output if the battery is good and check for corroded wires.
Last edited by jnn7404; 05-06-2007 at 11:42 AM. Reason: added more instead of being a POST WHORE!!!!!
jnn7404 is offline
post #12 of 29 (permalink) Old 05-08-2007, 06:56 PM Thread Starter
richrom2's Avatar
well i checked the coolant level and its fine.
richrom2 is offline
post #13 of 29 (permalink) Old 05-09-2007, 09:04 AM
Why is your bike in Celcius? You're in NJ.
post #14 of 29 (permalink) Old 05-09-2007, 06:20 PM Thread Starter
richrom2's Avatar
good question i have no idea. i got the bike in new york. today i noticed when i rev it up high it turns a little bit
richrom2 is offline
post #15 of 29 (permalink) Old 05-09-2007, 06:44 PM
dscort's Avatar
Check this thread.
sounds like a charging problem. id suggest getting a shop manual and checking voltage by manufactures specs.
if that checks out try bench testing the fan. my 929 fan quit for no reason, tested it, no good so got another on ebay. works fine now.
dscort is offline
post #16 of 29 (permalink) Old 05-09-2007, 07:05 PM Thread Starter
richrom2's Avatar
what do i have to do to check the charging system and also bench testing the fan?
richrom2 is offline
post #17 of 29 (permalink) Old 05-09-2007, 07:39 PM
dscort's Avatar
gonna need a voltage meter. my 929 manual says battery should be 13-13.2V fully charged. below 12.3 is under charged. w/ the bike running at normal temp it should be 15.5V at 5000rpm, w/ the hi beams on.
bench testing is unhooking the fan from the bike and supplying a relialble 12V source. battey charger on low setting or car battery. hook jumper wires to the fan, gonna have to find ground wire so you dont hook it up backwards, could cook the fan if backwards. then you know if the fan is good if it runs on a good 12V source.
a good manual will tell you wire colors (my honda fan ground is green) all bikes are different, and how to test electric components.
dscort is offline
post #18 of 29 (permalink) Old 05-09-2007, 09:21 PM
And a good switch. However, I also suggest doing this after the factory cooling fan switch. That way if you forget the fan will still come on when its suppose to.
However, I don't think that is the issue. It could be the battery. Is it holding a charge? But before you start throwing parts at it.. I suggest you do what dscort said... test the fan.
post #19 of 29 (permalink) Old 05-09-2007, 11:49 PM Thread Starter
richrom2's Avatar
yeah but my horn doesnt work most of the time and when it does and i use it everything goes dim when i blow the horn or when i use my turn signal everything then starts flickering.
would you guys consider this to be a run-on sentence
richrom2 is offline
post #20 of 29 (permalink) Old 05-10-2007, 12:59 PM
Still sounds like the charging system and/or battery.
Test that first.
