Speedometer stuck at zero - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 6 (permalink) Old 05-05-2007, 05:46 PM Thread Starter
Any one every run into that problem. My speedometer is stuck at zero what could be the cuase, any pointers will be greatly appreciated. My bike is an 06 GSXR 1000 if that helps any.
j_man is offline
post #2 of 6 (permalink) Old 05-05-2007, 09:45 PM
Do you any gearing changes done?
Have you checked your front speedo pick up?
post #3 of 6 (permalink) Old 05-07-2007, 01:22 PM
I love doing things myself... but warranty prevails!
post #4 of 6 (permalink) Old 05-07-2007, 02:09 PM
and check the wiring harness, maybe it got disconnected.
post #5 of 6 (permalink) Old 05-08-2007, 02:55 AM
All the tachomoeters have a reset function. Read the owners manual you would be surprised at how awesome it works. Also if the wiring harness is connected and the fuses are good, and the reset button doesnt work, you need to go talk to a suzuki dealer.
BarryP is offline
post #6 of 6 (permalink) Old 05-08-2007, 11:58 AM
Check your harness. Mine came disconnected and would cycle through it's little test when you turn the key to start it. It did this like every 30 seconds and sometimes the speedo would be stuck at 0.
rockinthef4i is offline
