Tires With Tube - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 5 (permalink) Old 05-06-2007, 09:07 PM Thread Starter
Tires With Tube
I HAVE THIS 1970 CB AND TIRE IS ALMOST GONE. WHERE CAN I FIND TIRES WITH TUBE? OR CAN I USE TUBELESS TIRES ON THE SAME RIM?>
ALSO CAN I GO ONE SIZE LARGER FOR THE REAR TIRE?
APPRACIATE YOUR HELP, THANKS GUYS
serkant3 is offline
post #2 of 5 (permalink) Old 05-06-2007, 09:14 PM
dscort's Avatar
try dennis kirk. they got alot of older sizes.
dscort is offline
post #3 of 5 (permalink) Old 05-07-2007, 07:54 AM
Caps lock is like the plague around here recently... no you cant use a tubeless tire because your wheel wasnt designed to hold air hence the tube
post #4 of 5 (permalink) Old 05-08-2007, 02:44 PM
rickmancc's Avatar
what size rim do you have? I have some tubes
rickmancc is offline
post #5 of 5 (permalink) Old 05-10-2007, 06:39 AM Thread Starter
i will check and let you know, just to make sure, thank you :-)
serkant3 is offline
