oil in the airbox - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 13 (permalink) Old 05-07-2007, 10:40 PM Thread Starter
oil in the airbox
i was changing my sparkplugs and while i was taking the air filter out i noticed that there was a small amount of oil in there(like a tablespoon). could this be a vacuum hose or pcv valve?
bike
2000 yamaha r6
ecksman is offline
post #2 of 13 (permalink) Old 05-07-2007, 11:19 PM
Not sure on that, If the valve cover is like a honda car, it might be the valve cover gasket, How far do the plugs go down in the valve cover?
Got any pics?
cloner_357 is offline
post #3 of 13 (permalink) Old 05-07-2007, 11:20 PM
erm, i read the message wrong, you ment in the air filter..
pcv valve possibly
post #4 of 13 (permalink) Old 05-07-2007, 11:34 PM
Its an accumulation of oil mist from the crankcase. A small amount of piston blow-by pushes it in there. Eventually, it will affect the breathability of your air filter. but fairly normal if you like to wind up those RPM's...
post #5 of 13 (permalink) Old 05-08-2007, 11:19 AM
However the PCV vale is suppost to stop this from happening. If it has one it may be bad. Or you have excessive amount of blow-by. This can be checked by putting you hane over the oil fill hole while the engine is running. If it blows past your hand, you have too much blow-by and bad rings. Find the PCV vale and remove it. (If it has one) Shake it to test, it should rattle in your hand.
777Customs is offline
post #6 of 13 (permalink) Old 05-08-2007, 09:19 PM Thread Starter
after doing a search i read that bikes dont have pcv's
ecksman is offline
post #7 of 13 (permalink) Old 05-09-2007, 10:57 AM
My 85 Interceptor did. But I'm not sure if newer bikes do or not.
post #8 of 13 (permalink) Old 05-09-2007, 05:45 PM
i dont know your bike, but it sounds like just the crank case breather. Look at the hoses attached the air box... one feed the engine case?
post #9 of 13 (permalink) Old 05-10-2007, 10:44 PM
Bikes don't have no pcvs...
It is from excessive crankcase and head pressure on the top end. The govt makes the bike manufactures "re-burn" that oil mist into the air box or intake. I bet there was a tube coming from the motor into the airbox...
post #10 of 13 (permalink) Old 05-11-2007, 10:59 AM
I did some reserch on my CBR. You are right there is no PCV valve per say. There is a check valve on the valve cover that stops fluid from entering the airbox to be burned. Like a pcv valve does.
post #11 of 13 (permalink) Old 05-11-2007, 02:24 PM
Well in that case... remove it and blow thru it... see if it flows in the correct direction and not in reverse...
post #12 of 13 (permalink) Old 05-11-2007, 02:47 PM
california models have an extra canister and plumming. i had one once. it was easy to remove. but the oil in the air box is somewhat normal. how many miles are on the bike?
post #13 of 13 (permalink) Old 05-11-2007, 09:28 PM
That is right. Cali models have to have an evap. emissions system for fuel vapor. Part of what is in the air box could be condensed fuel and oil vapor.
