GSXR not starting? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 21 (permalink) Old 05-10-2007, 10:23 PM Thread Starter
GSXR not starting?
K, I laid my bike down.. and now the ignition doesnt wana work.. i checked all the wires.. no broken wires.. but it's not getting power.. bat is fully charge.. all fuses are good.. any ideas?
cloner_357 is offline
post #2 of 21 (permalink) Old 05-10-2007, 11:03 PM
Tip Over Sensor
oldetymebiker is offline
post #3 of 21 (permalink) Old 05-10-2007, 11:06 PM Thread Starter
well, the ignition would turn on, but not let it start.. ignition isnt turning on at all.
post #4 of 21 (permalink) Old 05-11-2007, 12:20 AM
I think the tip-over switch shuts off the fuel, but there's lots of other things that can stop the ignition: neutral indicator, clutch lever, emergency switch, kickstand switch, ignition switch....
post #5 of 21 (permalink) Old 05-11-2007, 05:09 AM
My girlie had a similar problem. Check the switch on the clutch lever.
Sharons clutch lever must've bent a really small amount, not enough to be visible, and not enough for the clutch to stop working, but enough that the starter switch wouldn't make contact.
(in case this isn't how they work in the States, certain models of Suzukis require that you pull the clutch in to start them)
Chuckademus is offline
post #6 of 21 (permalink) Old 05-11-2007, 02:18 PM
Yeah but I think the ignition would still come on even with a bad clutch sensor.. may not start but the fuel pump should at least come on...
post #7 of 21 (permalink) Old 05-12-2007, 05:08 PM
Is your FI display on your tachometer? When I went down for the first time the tip over sensor came on. The bike wouldn't start for 35 minutes. Check for the FI display. If it doesn't go off just take it to a suzuki dealer, they'll fix it.
BarryP is offline
post #8 of 21 (permalink) Old 05-12-2007, 07:18 PM
Does anything work when you turn the key headlights, horn, signals, anything? And when you say broken wire do you mean loose or did you check them with a meter?
jnn7404 is offline
post #9 of 21 (permalink) Old 05-12-2007, 08:36 PM Thread Starter
nothing comes on. Key does nothing, no lights/horn/blinkers.. etc. like it's getting no power.. :\
post #10 of 21 (permalink) Old 05-12-2007, 08:53 PM
I would get a volt meter and check your harnesses. Staring with the ignition. The ignition switch might have took a crap.
jnn7404 is offline
post #11 of 21 (permalink) Old 05-12-2007, 09:40 PM
Hey buddy check your battery. It sounds to me like your bike isn't getting any voltage whatsoever. What exactly happened when you dumped your bike?
BarryP is offline
post #12 of 21 (permalink) Old 05-13-2007, 03:34 PM Thread Starter
comming around a turn.. leaned way to far.. and bike slid out nailed a cement wall. :\ bent the forks and ignition wont switch on.
Im gona go try it today. ill let you guys know.
post #13 of 21 (permalink) Old 05-13-2007, 04:34 PM
Well chit man if your front end took that much of a beating I'm willing to bet there are a few wires near the ignition that are mashed or mangled. I would honestly take it to the suzuki dealer that you bought it from. Be a straight shooter with them, they may have seen the problem before. Who knows. Don't act retarded about it though, they are automatically going to assume you're an idiot b/c you laid your **** down. Just find a cool mechanic and ask him if he'll check your **** for a 30 pack. That usually works for me.
BarryP is offline
post #14 of 21 (permalink) Old 05-13-2007, 05:37 PM Thread Starter
only issue is.. I have all my fairings off.. every thing is off.. and there are 2 mashed wires.. but i fixed em.. still no go.. i can see every wire perfectly.. im going to call the dealer tomorrow when there open..
On a good note.. my forks will be here this week
so i can get back at that turn
post #15 of 21 (permalink) Old 05-13-2007, 06:09 PM
Even tho its not working..Im glad that your ok..Thats the most important part!
Brizz is offline
post #16 of 21 (permalink) Old 05-13-2007, 06:21 PM Thread Starter
thanks
post #17 of 21 (permalink) Old 05-13-2007, 06:28 PM
Yeah all joking aside I'm glad you're ok too. My buddy has the same exact bike and he lowsided it three weeks ago. Gear works!
BarryP is offline
post #18 of 21 (permalink) Old 05-13-2007, 06:31 PM Thread Starter
i agree.. saved my ass.. but my fat rolls got scrapped up! lol
post #19 of 21 (permalink) Old 05-15-2007, 10:07 PM Thread Starter
ok, SHE STARTS! there is a seperate fuse from the fuse block, under the tail housing of the bike, I had to pull the whole tail fairings off to find it.. but she runs! Yay! forks will be here thursday!
post #20 of 21 (permalink) Old 05-15-2007, 11:31 PM
That is the main fuse for the starter I believe... I use to have one on the 9R.. I think that is what it was for...
