how to remove air filter - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 19 (permalink) Old 05-14-2007, 11:09 PM Thread Starter
richrom2's Avatar
im trying to remove the air filter to clean it but ive looked online on how to do it and i dont get it. they said i have to remove the two bolts that hold the gas tank down and the tank i suppose to swing up towards the handle bars. but when i tried to do that it wont swing up because of the hoses that are attached right under it are to short.
thanks for any replies
2003 mercedes clk55, 2005 lincoln aviator
richrom2 is offline
post #2 of 19 (permalink) Old 05-14-2007, 11:10 PM
Those are your fuel lines. Disconnect them.
post #3 of 19 (permalink) Old 05-14-2007, 11:41 PM
yep its that easy...
post #4 of 19 (permalink) Old 05-15-2007, 01:18 AM
should be 3 lines there, fuel line, vacuum pressure, and fuel pump wire. i am only relating to my bike. could be the same or not. first i take the 2 bolts off from the front and i find a 16 inch peice of wood or something to stable the gas tank in the 10ish or 11 o'clock area so u could work on those hose's. undo while remembering where each hose or wire go's... u should have enough room for you hands or tools. unbolt the airbox...walla
get a BMC or K&N .....
let us know how it goe's
later
Xxgsxr750xX
Pipe Fitter is offline
post #5 of 19 (permalink) Old 05-15-2007, 06:04 AM Thread Starter
richrom2's Avatar
the manual is saying in big black bold letters not to disconnect them
richrom2 is offline
post #6 of 19 (permalink) Old 05-15-2007, 06:39 AM
I bet it doesn't want you to mod your bike either.
post #7 of 19 (permalink) Old 05-15-2007, 06:58 AM
Reach under the bike and pull the tubes from the fairing. They are probably being held in place by a small metal Ring of sometype. Just remove them from the ring and it will free up enough slack so you can raise your tank without disconnecting them...or you could just disconnect them. As long as the bikes not running that **** doesn't matter anyway.
BarryP is offline
post #8 of 19 (permalink) Old 05-15-2007, 10:50 AM
true true.. might be some plastic clip or something so the hose's don't fly around, try to look for that. undo that and free up some room.shouldn't really have to undo fuel lines for filter replacement. but to each is own, some models could be different. If all else fails have a tech change it.
post #9 of 19 (permalink) Old 05-15-2007, 11:12 AM
If you have a tech change your filter I will fly out to where you live and pee on your bike.
BarryP is offline
post #10 of 19 (permalink) Old 05-15-2007, 03:52 PM
I didn't have to disconnect ****.
I just removed the seat...removed the two bolts and it just swings up...put the pole under it and walla....just like the hood on a car....undo bolts pull out old filter place new filter bolt back down....remove pole....lower tank...replace bolts....replace seats....5 min...tops....
post #11 of 19 (permalink) Old 05-15-2007, 04:48 PM
if the fuel lines are too short, you can replace them with longer ones. goto your local autoshop for fuel lines. make it long enough so you can move the tank to the seat. take note on how it's routed so it doesn't get pinched.
post #12 of 19 (permalink) Old 05-15-2007, 07:04 PM Thread Starter
richrom2's Avatar
thats how its saying it should be, but that not the case.
richrom2 is offline
post #13 of 19 (permalink) Old 05-15-2007, 07:09 PM
post up a pic...and lets see if we can see what the dealie O' is....
post #14 of 19 (permalink) Old 05-15-2007, 10:13 PM
just them and patch it with duct tape when you're done.
post #15 of 19 (permalink) Old 05-15-2007, 10:16 PM
I like your style.
post #16 of 19 (permalink) Old 05-16-2007, 07:31 AM
I like your style.
I like your hair.
BarryP is offline
post #17 of 19 (permalink) Old 05-17-2007, 04:14 AM
I like your hair.
post #18 of 19 (permalink) Old 05-20-2007, 11:36 PM
I like your hair.
The one compliment that raises an eyebrow when coming from a midget... That and your breath smells nice...
post #19 of 19 (permalink) Old 05-21-2007, 07:36 AM
What the hell.....
BarryP is offline
