How cold natured is your bike? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 18 (permalink) Old 11-18-2004, 03:14 AM Thread Starter
Have problems starting it up after its been sitting for awhile? especially in the colder weather? do you ride less often in the cold because it can take longer to warm up?
I know my Kat is notorius for being cold blooded..if I dont choke the hell out of it, she'll carry on like a banshee till the blood starts flowin. It's not near as bad now as it was b/4 I got the carbs cleaned out and new plugs put in. If I choke her really good, she starts right up now and stays running, but still a bit rough. just par for the course.
but it doesnt stop me from riding though, i'll deal with it!
Need4Speed is offline
post #2 of 18 (permalink) Old 11-18-2004, 06:59 AM
My 9R isn't really that bad.... now my EX500 was like your Kat... till I got it re-jetted and that help alot.
post #3 of 18 (permalink) Old 11-18-2004, 10:09 PM
If it makes you feel any better, the can-o-tuna is pretty notorious for being cold blooded (so are most air-cooled bikes but it's fun to pick on the Kat).
post #4 of 18 (permalink) Old 11-18-2004, 10:17 PM
I have yet to choke mine. I just started her up and good to go. The only time I have used the choke is to help warm her up faster and then I am gone.
GSXR1000DJ is offline
post #5 of 18 (permalink) Old 11-18-2004, 10:21 PM
Look who's back!!
post #6 of 18 (permalink) Old 11-18-2004, 10:22 PM
Move to FLA and buy a Honda...That way you can eliminate both your problems
post #7 of 18 (permalink) Old 11-18-2004, 10:24 PM Thread Starter
geez even the resident expert has no love for the Kat
post #8 of 18 (permalink) Old 11-18-2004, 10:27 PM
Originally Posted by Gas Man
Look who's back!!
Its only been a few days. LOL When I'm off I normally don't get on the computer to much. I try to spend time with my little ones. Sorry for jacking this thread. Opps
post #9 of 18 (permalink) Old 11-18-2004, 11:30 PM
pickup an ignition advancer. cuts warm up time 1/2
rockadaous is offline
post #10 of 18 (permalink) Old 11-18-2004, 11:32 PM Thread Starter
yeah boy..pretty inexpensive mod that's well worth it!
post #11 of 18 (permalink) Old 11-19-2004, 12:38 AM
Expensive nothing!! You can get those pretty cheap!! Like $65 or so...
post #12 of 18 (permalink) Old 11-19-2004, 12:45 AM
My Honda requires full choke to idle at 1,500. My old Suzuki requires full choke to start, then revs to 4,000 until I quick open the choke. I thought all Suzuki's reved high with start-up choke. Your carb cleaning might not have cleaned the choke circuit.
You could manually drain your carbs (PIA) or run the engine with gas off to drain the carbs. With the engine cold, put a can of Gumout in the fuel line to fill the float chambers. Start the engine with the choke full on and the Gumout will flow through the choke circuit. If it had clogs, the idle RPM should increase. The Gumout won't be there long enough to attack any rubber parts.
post #13 of 18 (permalink) Old 11-19-2004, 12:55 AM Thread Starter
it used to be ALOT worse, trust me..so bad that i'd have to try and start it like 20 times b/4 it would turn over..if I choke it atleast 50%, she starts right up and is fine..but if I dont, wow!!
post #14 of 18 (permalink) Old 11-20-2004, 01:59 PM
Sorry man, I had to
Anyway, the real answer is every bike should need a little choke (enrichener) to start. After that, I prefer to turn off the excess fuel as soon as it will take a little throttle without it. I then let it warm up on its own (this is also a good time to do your pre-ride inspection). Every bike is different, but air cooled bikes with stock jetting are the worst in how long they take to warm up and get happy.
post #15 of 18 (permalink) Old 11-20-2004, 02:15 PM Thread Starter
the dealer also mentioned that its not good to let them idle too long..kats especially..he said it fouls out the plugs, and he just chokes it start, lets it run for about 30 seconds or so, and away he goes... ?
post #16 of 18 (permalink) Old 11-20-2004, 02:28 PM
I have still yet to choke mine to have to start her. I normally let mine warm up to 90-95 degrees before I ride.
post #17 of 18 (permalink) Old 11-20-2004, 10:18 PM
Everyone has their own method, although I would argue that a bike that fouls the plugs at idle needs the carbs adjusted properly. And I still say that if you don't need the choke, your bike is too rich on at least the pilot circuit.
Just my $.02,
post #18 of 18 (permalink) Old 11-24-2004, 05:00 PM
The Aprilia doesn't even like to start in sub 30 degree weather. Throttle up is mandatory until the engine temp reaches about 120.
Mojo is offline
