Transmission gear install ?'s - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 4 (permalink) Old 05-25-2007, 08:54 PM Thread Starter
My buddy and I are currently rebuilding his CBR F3. Finally. We are putting the transmission back in right now, and my question is, are the transmision gears allowed to have a little side to side slop or are they supposed to be very tight?
now my fiance wants me to put a couple of these little things in the post:
Kevin
2002rt is offline
post #2 of 4 (permalink) Old 05-26-2007, 01:49 AM
there can be a little play....not much, i would say 1, maybe 2mm at most
binder929rr is offline
post #3 of 4 (permalink) Old 05-26-2007, 02:28 AM Thread Starter
I would say that there mightbe 4mm play side to side. It seems overall alot tighter now that we installed the shift drum and the shift forks, however I cannot get any accurate view of the gears that sit under the shift drum. I will double check tomorrow the exact amount of play.
Kevin
2002rt is offline
post #4 of 4 (permalink) Old 05-26-2007, 04:17 PM
if you have 4mm, which is near half a CM, i would seriously advice not putting it together. check to make sure you have all the washers on the ends of the shafts. that is way too much slop.
now, don't count the sliders, those are suppose to move back and forth, but the shafts, they don't move that much.
