can it be tranny or clutch - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 20 (permalink) Old 05-29-2007, 07:10 PM Thread Starter
richrom2's Avatar
i was riding to philadelphia to a bike shop and when i was on the bridge i felt a little jerk. i gave it more gas and noticed that it revved up high then the rpm needle went to zero and then back to the rpms that it suppose to be. today when i was riding i was keeping it at a steady pace when i felt the little jerk again the saw the rpm needle go to zero, then back to the rpms it suppose to be and when i gave it gas it felt like it was slipping again. what can it be?
2003 mercedes clk55, 2005 lincoln aviator
richrom2 is offline
post #2 of 20 (permalink) Old 05-30-2007, 07:08 PM Thread Starter
richrom2's Avatar
does anybody have any idea, should i be more detailed?
richrom2 is offline
post #3 of 20 (permalink) Old 05-30-2007, 08:14 PM
sounds like either your clutch...*more than likely
or your transmission *less likely
I would start with the clutch.
post #4 of 20 (permalink) Old 05-31-2007, 09:58 AM
I would say clutch but the fact that the RPMs go to zero steers me away from that.
What did the actual motor do by sound? Were you giving it throttle? did you gain any speed? did the tach come back?
post #5 of 20 (permalink) Old 05-31-2007, 12:59 PM
Without the tach thing, I would definitely say clutch. Since the tach is going berzerk, I would lean towards something electrical. A slipping clutch alone will not cause the tach to bounce to 0. The tach is measuring how fast the engine is turning, regardless of what is going on in the tranny.
6doublefive321 is offline
post #6 of 20 (permalink) Old 05-31-2007, 03:50 PM
start with electrical. checking for loose connections at your gauge cluster, stator etc. if the tach goes from cruising speed to 0 and back to cruising speed again, its not a clutch issue unless the motor does the same thing.
post #7 of 20 (permalink) Old 05-31-2007, 06:06 PM
I Had A Similar Problem With My Gauge Cluster...it Was Cause My Battery Was Giving Off 16v Of Electricity Cause My Retifier Was Screwed Up And It Eventually Shorted Out My Whole Dash...but If Its A Clutch Problem Check It Its Really Easy...go At A Steady Speed Like 40mph And Mash On The Gas If The Rpms Start To Climb And Your Speed Isnt Goin Up Either Then Its Your Clutch, But Im Leaning Toward Electrical
Double_R is offline
post #8 of 20 (permalink) Old 05-31-2007, 07:14 PM Thread Starter
richrom2's Avatar
i did that and when i did it i saw the rpms go up and i heard the bike but it just wouldnt grab until i let off the gas and gradually gave it gas, gaining speed.
richrom2 is offline
post #9 of 20 (permalink) Old 05-31-2007, 07:27 PM
That sounds like a slipping clutch. However, it does not explain the tach issues.
post #10 of 20 (permalink) Old 06-01-2007, 07:32 AM Thread Starter
richrom2's Avatar
also at times when im going at a steady pace i sometimes feel the bike jerk a little and i noticed that the rpm needle goes down a little too.
richrom2 is offline
post #11 of 20 (permalink) Old 06-01-2007, 07:41 AM
Might be multiple things going on here. If you ignore tach... does it sound like a bad clutch? If so... go for that. And then deal with the dash/tach.
post #12 of 20 (permalink) Old 06-01-2007, 01:11 PM
Dude You Just Might Need A Tune Up Including Fuel And Spark, Besides The Clutch
Double_R is offline
post #13 of 20 (permalink) Old 06-02-2007, 12:46 AM
A bad clutch probably won't slip now and then. It would slip all the time. But electric problems are intermittent. Especially since most newer tachs read off the spark unit. If the spark unit has a bad connection or is actually going bad, it will throw weird sparks and/or send bad vibes to the tach. I would check the connections first.
post #14 of 20 (permalink) Old 06-02-2007, 01:42 AM Thread Starter
richrom2's Avatar
theres times when ive stompped on the gas and it wouldnt catch and when i gradually gave it gas it would gain speed so maybe the clutch isnt totally gone but going. also my clutch grabs high. high to where i practically let go and it would grab
richrom2 is offline
post #15 of 20 (permalink) Old 06-02-2007, 07:47 PM
When you say "grabs high" do you mean the distance on the lever? Cause that could just be a freeplay adjustment...
post #16 of 20 (permalink) Old 06-05-2007, 12:09 AM Thread Starter
richrom2's Avatar
yeah i practically have to let it go all the way before it grabs
richrom2 is offline
post #17 of 20 (permalink) Old 06-05-2007, 03:27 PM
Yeah that should just be in the freeplay.
post #18 of 20 (permalink) Old 06-11-2007, 11:02 PM Thread Starter
richrom2's Avatar
well i figured out the tach issue. when i went to turn the bike on the bike went dead. so i checked the battery and noticed that the screw to the positive cable wasnt screwed in all the way not having a solid connection
richrom2 is offline
post #19 of 20 (permalink) Old 06-12-2007, 04:50 PM
DUH!
post #20 of 20 (permalink) Old 06-12-2007, 08:30 PM
That'll do it.
