TLR stalls - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 14 (permalink) Old 05-31-2007, 11:46 AM Thread Starter
TLR stalls
Question for all of you wise and knowledgeable motorcycle gurus:
Any ideas on what would cause a 1999 TLR, 1280 miles, yosh exhaust, to stall immediately if rpm's are below 1000-1500. It runs like a champ if r's kept up, but dies right now if they drop to idle. It will not sit and idle, just shuts off. It has been sitting for about a year. There is stabilizer in the tank and it has been topped off with 92 octane fuel.
Thanks much!
Dragonfire is offline
post #2 of 14 (permalink) Old 05-31-2007, 11:48 AM
Thanks much!
1,280 miles on a '99!!!
Clean the carbs...
post #3 of 14 (permalink) Old 05-31-2007, 11:50 AM
drain tank, change fuel filter (if it has one), clean the carbs, refil with fresh gas and then RIDE THE THING!!!
Where did you ever find a 99 with that low of miles!!?!?!?!?!
post #4 of 14 (permalink) Old 05-31-2007, 12:00 PM Thread Starter
It's FI not carbed but those are good ideas. A friend of a buddy of a friend has been storing it and the guys goes back and forth from Brazil for work, he bought a BMW and I'm lookin at the TLR.
post #5 of 14 (permalink) Old 05-31-2007, 12:11 PM
Yeah... I think I knew those things were FI... My bad... Either way, same thing... clean the fuel system...
post #6 of 14 (permalink) Old 05-31-2007, 12:14 PM
Completly drain fuel system, put fresh gas in it, install new spark plugs and air filter. You should be good to go.
post #7 of 14 (permalink) Old 05-31-2007, 12:55 PM
I had a '98 TLS with the Yoshi RS3 cans. It did the same thing, just not every time. Turns out, it had to be remapped. TLs are notorious for having funky maps, and changing anything at all causes them to have fits. A remap is usually one hour of labor at a Suzuki shop, and was worth every penny in my case. Even if the map is not the culprit, you will still benefit from an updated map.
6doublefive321 is offline
post #8 of 14 (permalink) Old 05-31-2007, 07:49 PM
It's an 8 yr old bike with no miles....stabilizers are only good for about 3-6 mos. I would dump the fuel, change the fuel filter, do an oil change, put in a fresh battery (don't be cheap, it's prolly shot) and then run a couple tanks of Chevron through it before I did anything else. If it's still stumbling after that, go have it remapped.
oldetymebiker is offline
post #9 of 14 (permalink) Old 05-31-2007, 08:18 PM
dscort's Avatar
prolly got a injector half plugged w/ old gas. might have to pop off the throttle bodies and clean them good.
power commander is a must for those bikes too. takes out that hesitation and popping through the air box.
dscort is offline
post #10 of 14 (permalink) Old 06-01-2007, 01:13 AM
I want that Tiller.
post #11 of 14 (permalink) Old 06-01-2007, 12:12 PM
I want that Tiller.
I got an idea Dragon... Trade marko your Tiller straight up for his GSXR 750... From what I gather, it runs REAL well...
post #12 of 14 (permalink) Old 06-02-2007, 01:31 PM
You need to pull codes with a diagnostic tool but it sounds a bit like a bad TPS
FD2BLK is offline
post #13 of 14 (permalink) Old 06-02-2007, 09:02 PM
Yeah I was going to say the MAP. check the idle too!
I would clean the fuel system COMPLETELY even if it wasn't having problems!!
Use some sea foam on the throttle bodies at least!!
post #14 of 14 (permalink) Old 07-26-2007, 03:58 PM Thread Starter
Thanks guys! I know it's been a minute since I asked, but I did figure it out. The choke was gummed up and wouldn't adjust. Fun part-->got it runnin and the guy sold it out from under me. gotta love it! So I ended up finding an '03 SV1k with 2800 miles on it and am flogging that for now. Thanks again!
