really strange problem with engine tonight - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 20 (permalink) Old 06-04-2007, 12:20 AM Thread Starter
So my bike just started behaving really oddly tonight. When i start it up it will die without any choke, even when fully warmed up. The rpm's will also shoot up really really high and will not come down. if i take away the choke it will idle but when i try to give it gas it will die right away as soon as i touch the throttle. if i let the clutch out when the rpm's are high I can get it to go, but if i try to give it more gas while it is rolling it will die, also the rpm's don't drop once it is rolling along with the clutch out and i was able to go 35mph in 2nd gear to get myself home. (it started happening a mile away from my house).
I have already bought all amsoil oil, and an air filter, amsoil carb/injector spray cleaner, so I'm ready to go for a full tune up, and I just cleaned/lubed the chain today.
I think this may be a bit much for me to take on myself since i've never worked on a bike before. Sounds like it could be an easy problem to fix.
i have a cbr 600F3.
ptowntsi is offline
post #2 of 20 (permalink) Old 06-04-2007, 12:23 AM Thread Starter
i have a cbr 600F3.
ptowntsi is offline
post #3 of 20 (permalink) Old 06-04-2007, 07:44 PM Thread Starter
i will pay you whatever you feel is fair for the work done. not trying to get somethin for nothin at all.
ptowntsi is offline
post #4 of 20 (permalink) Old 06-05-2007, 12:42 PM
if you think its complicated, get the service manual for your bike. trust me, it'll save you a ton of headaches in working on it.
post #5 of 20 (permalink) Old 06-05-2007, 03:22 PM
i have a cbr 600F3.
Dang. It could be a number of things. I would do the simple things first: check the throttle cable linkage; check for damaged or loose vacuum lines; do what you had planned with the carb cleaner / filter. If its not one of those simple things (and I doubt it is), get the manual or take it to the shop.
6doublefive321 is offline
post #6 of 20 (permalink) Old 06-05-2007, 06:07 PM
Not sure... do the tune up and check back.
Further, I merged your threads leaving a redirect in Honda and the west section.
post #7 of 20 (permalink) Old 06-06-2007, 01:12 AM
Ok what were you doing when it started acting up? I know my friends like to play pranks on each other and I have seen them loosen the idle adjustment so a bike wont idle or loosen or tighten the throttle cable.. I don't know if you have a$$hole (friends) like that or not but its just some food for thought...
+1 for a shop manual!!!
Joe4g63gsx is offline
post #8 of 20 (permalink) Old 06-06-2007, 01:33 AM
post #9 of 20 (permalink) Old 06-06-2007, 01:55 AM Thread Starter
yea i got the service manual, just not sure where to go.
right now i'm thinking the choke is stuck open or not shutting off all the way. it feels very stiff to move it and even then it only opens or closes in the final 1/2" of travel going towards the choke being "on".
if the choke is not shutting off all the way couldn't this cause a bogging problem?
when it is idling, it is not very smooth, and if i blip the throttle it dies. if i slowly give it gas its fine. also when riding if i twist the throttle back quickly it bogs before taking off.
bad plugs? choke not shutting off? bad fuel filter?
ptowntsi is offline
post #10 of 20 (permalink) Old 06-06-2007, 02:04 AM
Plugs and a fuel filter are cheep and won't hurt to change! Hell If you are in that far you should be able to check the choke cable and make sure its working proper. Lube it as well.
Let us know if that works for you!
post #11 of 20 (permalink) Old 06-06-2007, 02:09 AM
sounds like an vacum leak to me, but hard to say. you can try spraying carb cleaner or starter fliud around the bases of the carbs n lines. If theres a leak the motor should rev up. Far as the carb cleaning form you got it would be best to take the air filter out n spray into the carbs.
post #12 of 20 (permalink) Old 06-06-2007, 03:10 AM Thread Starter
but if the air filter is out then that means the tank is off, which means i can't spray into the carbs while the motor is running, and that is what amsoil recommends for this stuff.
http://www.amsoil.com/storefront/apf.aspx
ptowntsi is offline
post #13 of 20 (permalink) Old 06-06-2007, 04:35 AM
2 options
1. get a long piece of fuel line n rig the tank up or
2. get a piece of fuel line n a container with gas in it
you get the idea...
post #14 of 20 (permalink) Old 06-06-2007, 09:50 AM Thread Starter
haha! ill put some gas in a funnel and then put the funnel in the gas hose! voila. man i could go to town on that sumbitch lol.
ptowntsi is offline
post #15 of 20 (permalink) Old 06-07-2007, 09:39 PM Thread Starter
i stopped by the honda dealer tonight after getting a new fuel filter from them and one of the tech's looked at my bike for about 30 seconds before he said he thinks its a vacuum leak. what hoses could cause a vacuum leak or do you think its a manifold/carburator leak.
ptowntsi is offline
post #16 of 20 (permalink) Old 06-07-2007, 09:56 PM
dscort's Avatar
the manual should have vaccum routing diagrams. intake manifold leaks can be found w. carb cleaner sprayed on them while running. will miss a little if the carb cleaner is sucked in to the leak in the manifold. not 100% sure on if its carb cleaner so someone chime in if im wrong
dscort is offline
post #17 of 20 (permalink) Old 06-08-2007, 12:02 AM
carb cleaner will work as will starter fluid which is what I always prefered as it makes the engine rev higher. Either will get the job done tho.
post #18 of 20 (permalink) Old 06-08-2007, 08:42 AM
Starting fluid go boom!
post #19 of 20 (permalink) Old 06-08-2007, 06:14 PM
And carb. cleaner does burn so be causious. Spray around the tubes that connect the carbt to intake, the carb bodies themselves, and any hoses that come off of them. Also try to pinch off hoses to see if the idle changes. DO NOT SPRAY ANY IGNITION COMPONENT WHILE RUNNING!!
777Customs is offline
post #20 of 20 (permalink) Old 06-09-2007, 02:39 AM
brake cleaner and wd40 will also work. That's a old school trick. Its just that the wd40 gets all over everything and doesn't evaperate like the cleaners do.
