Bearing Noise under sprocket cover - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 20 (permalink) Old 06-07-2007, 04:05 PM Thread Starter
I have a 01 Gixxer 750 with 3,600 miles I keep hearing this scratching noise from what I thought it was the brakes but after further investigation i found out it was comming from underneath the front sprocket cover... Is this normal for gixxers or should i be really concerned... what do you guys think it could be and how pricey is it to fix.
post #2 of 20 (permalink) Old 06-07-2007, 04:15 PM
Have you removed the sprocket cover and investigated yet?
post #3 of 20 (permalink) Old 06-07-2007, 04:20 PM Thread Starter
No I havent but I am wondering if this is common for these bikes or if its something I should be really worried about it... I squirted some chain lube in there to band-ade the problem for the time being and it fixed it for now.... I really am not a good wrench so this problem is way out of my abilities.
post #4 of 20 (permalink) Old 06-08-2007, 03:46 AM
Maybe you needed to clean/lube the chain anyway?
post #5 of 20 (permalink) Old 06-09-2007, 01:37 AM
I have never heard of it... could be the clutch basket on the other side? Not sure...
post #6 of 20 (permalink) Old 06-09-2007, 07:53 AM Thread Starter
I am going to try taking off the over and cleaning up the are i think its a build up of the old chain lube (suzuki chain lube sucks it makes a mess of everything) and gunk... I can see a glob built up on the inside of the left ferring i can only imagine whats under that cover... I clean that up and see what happens.
post #7 of 20 (permalink) Old 06-09-2007, 11:33 AM
Ha! You guys lube your chains!!!
Buell owner for 1 week and I flucking love it!!!
post #8 of 20 (permalink) Old 06-09-2007, 01:08 PM
only need to clean the chain, not necessarily lube it (that's what the o-ring is for). only need to lube non-o-ring chains (usually for track bikes).
i would check the sprock teeth and also check chain slack.
3k miles isn't much mileage to wear out the chain/sprocket, but do tell use what you find. or post pix. it may have picked up debri
post #9 of 20 (permalink) Old 06-11-2007, 12:25 AM
That is true... that's why I would clean my x-ring DiD with kero fuel. It is a oil anyway so it cleans and lubes in one motion.
post #10 of 20 (permalink) Old 06-16-2007, 08:18 PM
Check the slack on your chain it happerned to me. I happened to beat the hell out of my chain and it made the same noise. I didn't have alot of miles on it either. Got a new gold chain and no more noise.
gparz74 is offline
post #11 of 20 (permalink) Old 06-16-2007, 08:28 PM Thread Starter
I pulled the cover and cleaned it up with degreaser all around the sprocket... and then I noticed the a bolt and washer thingy that the speedo sensor reads was loose and bout ready to fall off... So i think a combo between the road grime and loose bolt created that noise.
post #12 of 20 (permalink) Old 06-17-2007, 12:15 AM
So clean it all up. Apply loctite to the bolt. Re-assemble and test ride. Report back to us.
post #13 of 20 (permalink) Old 06-20-2007, 11:38 AM Thread Starter
it works perfect now.... All better now speedo problem and strange noise fixed... and the drain plug is all tapped out and fixed now too.
post #14 of 20 (permalink) Old 06-20-2007, 08:03 PM
What was the fix on the speedo problem?
post #15 of 20 (permalink) Old 06-20-2007, 08:56 PM
tightening the nut/speedo/combo/thingie was probably it.
post #16 of 20 (permalink) Old 06-20-2007, 10:01 PM Thread Starter
You got it tightening the nut fixed it right up
post #17 of 20 (permalink) Old 06-21-2007, 12:09 AM
Give it a few more weeks, I haven't seen a Buell that hasn't started leaking oil. The last one started after only 500 miles.
Big Kahuna is offline
post #18 of 20 (permalink) Old 06-21-2007, 09:31 AM
Good deal. Glad it was somin easy. Did you torque it to specs? Or just use the german meathod?
Alot of that is due to vibrations loosening stuff. With any v-twin, especially those 45 degree jobers... you need to have a regular tightening maintance.
post #19 of 20 (permalink) Old 06-21-2007, 09:17 PM Thread Starter
whats the german method.... i couldnt find any torque specs for it so i just buttoned it down nice and snug.
post #20 of 20 (permalink) Old 06-21-2007, 09:18 PM
German meathod.
Good n tite!
In this case... usually as much as your impact will do.
