I have an oil level Question - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 06-19-2007, 10:42 AM Thread Starter
When checking your oil your supposed to do it with the motor off right.... Because with my plug situation I threw on of those rubber expanding deals in just as a bandaid so i could get it to the mechanic and at every light I would dismount and check the levels but I was doing it with the bike running... I dismounted once and didnt see any oil in the glass and panniced and killed the bike and pulled it over... didnt look like any leaked out no drippys or nothing so I looked at it with it not running and added a 1/2 of a quart and it was sufficiently topped off... So when your bike is running and you look in the glass will it give a false level due to the oil pump putting oil else where.
post #2 of 7 (permalink) Old 06-19-2007, 10:51 AM
Correct, check it while it is off.
I had to ask a week ago and is how I know. LOL
Danase is offline
post #3 of 7 (permalink) Old 06-19-2007, 10:55 AM
Yes Window Will Give You False Reading While It Is Running Due To Oil Circulating Through Engine It Will Seem Empty. Sorry For The Caps I Do All My Drafting Text At Work In Caps.
papapoi is offline
post #4 of 7 (permalink) Old 06-19-2007, 01:07 PM
post #5 of 7 (permalink) Old 06-19-2007, 01:33 PM
Make sure the bike is level too not sitting on the kickstand
post #6 of 7 (permalink) Old 06-19-2007, 01:51 PM
, it sounds like you have a glass meter, but if you have a dipstick, turn the bike off, set it upright, pull out the dipstick and clean it, put it back in, pull it out, and take the reading.
that was dirty sounding...
post #7 of 7 (permalink) Old 06-20-2007, 09:30 AM
Take note, however, that most manufactures say you read the screw in style dipsticks without screwing the dipstick back in.
