And ONE MORE THING: bike trouble - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 13 (permalink) Old 06-21-2007, 08:37 PM Thread Starter
SO, thankfully the new battery problem is solved, but the only other thing is, since i got in the mild accident, my ninja 600 is sounding like a harley when I rev the engine.. not full out harley, but basically it sounds like the engine is muffled, like it's nose is clogged and has a gag over it's mouth. haha.. This SHOULD be the last thread I post but yeah, like I said it's happened ever since the accident, which I dropped it going a little over 20 on its left side. any information or suggestions would be very very helpful, and thanks in advance.
I've had a lot of good advice from everyone on here so hopefully it'll happen again
--Andy
th3her3tic is offline
post #2 of 13 (permalink) Old 06-21-2007, 08:47 PM
--Andy
carburated or fuel-injected? If its carb'd it may have dislodged some gunk in the carbs. Clean the carbs and that should clear it up. If its injected I aint sure what it may be, but I'm sure someone here will.
post #3 of 13 (permalink) Old 06-21-2007, 09:11 PM Thread Starter
I hear cleaning the carbs is a pain in the ass. hardcore. any tutorials or anything on howto?
post #4 of 13 (permalink) Old 06-21-2007, 09:15 PM Thread Starter
also, is there any immediate danger I should be cautioned about while driving with gunky carbs?
post #5 of 13 (permalink) Old 06-21-2007, 09:21 PM
I dont know of any off hand GasMan may know of or have one.
depends on how bad it is lol. shouldnt hurt the bike really except for maybe fouling the plugs. If its not running right tho I wouldnt ride it until its fixed.
post #6 of 13 (permalink) Old 06-21-2007, 10:14 PM
Moving this thread to Tech as well...
Anyway... have you checked your plugs?
You could try to just seafoam the carbs...
So it ran fine prior to the lower speed crash?
Have you checked the oil? Is there any gas in it?
How is the idle? Low?
post #7 of 13 (permalink) Old 06-22-2007, 12:50 AM
the one thing I thought of that hasnt been mentioned, do you have a header on each side? I know some of the kawi's had a 4:1 and some a 4:2 pipe setup with mufflers on both sides, similar to the EX500, but with four cylinders.
anyways, what I'm thinking is maybe you knocked a header loose at the motor. check all your header bolts, should be 10mm nuts on each one, and they're simple to tighten.
post #8 of 13 (permalink) Old 06-22-2007, 03:51 AM Thread Starter
haven't checked the plugs yet, it ran BETTER before the crash, yes. oil is good, gas is good, and idle seems pretty low, at times it seems like it's about to stall.. and I just found out on a test ride 5 min ago, the harley sound dissipates as I rev the engine, so basically I've been shifting a bit late, and its stopping the sound..
post #9 of 13 (permalink) Old 06-22-2007, 03:53 AM Thread Starter
I'll definitely do that tomorrow when I have sunlight. thanks
post #10 of 13 (permalink) Old 06-22-2007, 08:05 AM
Did you possibly bent the exhaust on it? That will change the way it sounds.
post #11 of 13 (permalink) Old 06-22-2007, 03:42 PM
To me, sounding like a Harley means it's only running on two cylinders. The first thing I would do is take out all four spark plugs and keep them in order. I put mine in four numbered holes in a piece of cardboard.
post #12 of 13 (permalink) Old 06-23-2007, 04:08 PM
Yeah...got to check the plugs for sure...
post #13 of 13 (permalink) Old 06-23-2007, 06:00 PM
coulda even knocked a plug wire or two off
dnyce is offline
