05' R1 Oil Light - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 06-26-2007, 10:24 PM Thread Starter
Question 05' R1 Oil Light
HAVING PROB. WITH OIL LIGHT ON 05 R1! IT STARTIED FLASHING INTERMITTENLY,SO I DRAINED OIL. THEN REMOVED FLOAT, SEEMED TO BE STICKING SO I CLEANED IT CHECKED STRAINER AND CLEANED IT ALSO.REASSEMBLED ADDED MY MOTUL 15/50 (full synthetic) AFTER ALSO NEW K&N OIL FILT.. I THEN TRACED WHITE LEAD WIRE FROM FLOAT SAW A NICK RE SPLICED AND INSULATED! REMOVED BATT. GAVE IT A FULL CHARGE RE-INSTALLED BATT., TURNED KEY ONLY TO HAVE THE LIGHT COME ON AGAIN, NOW INSTEAD OF FLASHING IT WAS NOW JUST STAYING ON !! WHEN I START IT OIL DROPS OUT OF WINDOW SITE AND CAN BE SEEN SQUIRTING BACK IN WHEN IT'S REVVED A LITTLE. WAS WONDERING IF ANYONE KNOWS OR HAS INSITE ON PROBLEM. DOES THAT RED OIL LIGHT ONLY WARN IF LEVEL IS DROPPING OR DOES IT KNOW LIKE IF SPRAYERS OR POSSIBLE OTHER PASSAGES ARE BLOCKED. WOULD APPRECIATE ANY HELP BEFORE I MIGHT HAVE TO PUT HER IN THE SHOP FOR PRICEY DIAGNOSTICS!
ASPAULTASASSINATION1 is offline
post #2 of 7 (permalink) Old 06-27-2007, 12:00 AM
First off...
Second, the oil light...more than likely, it doesn't have anything to do with flow. It is a oil pressure sensor.
I bet if you could find a service manual you could test the sensor with a multi-meter.
post #3 of 7 (permalink) Old 06-27-2007, 12:24 AM
secondly, are you sure you checked the oil sensor? there are a few sensors on the engines for these bikes, you may have accidentally looked at the neutral sensor, and thought it was the oil pressure sensor.
what I would suggest, is take the oil pressure sensor out, clean what dirt you see off it, and you may have it done.
post #4 of 7 (permalink) Old 06-27-2007, 01:00 AM Thread Starter
I checked with meter, but like i said it was th float in bottom of pan it checked out . I will look on cd manual 4 sensor. Do you know anything bout blow out valve /oil pressure relief?
post #5 of 7 (permalink) Old 06-27-2007, 01:03 AM Thread Starter
post #6 of 7 (permalink) Old 06-27-2007, 05:53 AM
now a low oil pressure causing the oil pressure light to stay on because of a pressure relief valve being stuck open or partially open is a possibility. why it'd be in such condition I dont know though.
post #7 of 7 (permalink) Old 06-27-2007, 07:04 PM
And you are dealing with 2 sperate things but 1 problem. If the pressure relief vlv is stuck open causing you to have low oil pressure and the light to come on. Then your problem is the vlv not the sensor.
