What do you do to WiNtErIzE? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 20 (permalink) Old 11-28-2004, 06:12 AM Thread Starter
Arrow What do you do to WiNtErIzE?
I know it's nothing we like to talk about but I need to hear some more techincal posting. Just getting a bit Off Topic'ed out!
Let's hear what you do to put your bike to sleep for the long winter...
I know that there is alot of website links out there with crazy amounts of things to do for winterizing your MC! I also know alot of people that don't do anything! Park it, and just recharge the battery in the spring!
I like to go somewhere in the middle of all that craziness!
I usually only pull the battery, stabil the gas, wash/wax, oil change, put 'er up on stands and that's it. This year I went a few steps farther...
1. Rode to gas station, put in stabil, filled it WAY up!
2. Rode it home
3. Changed the oil & filter, while motor was hot (always the best time to change oil on any motor)!!!!!
4. Re-start with petcock off
5. Let run till it started to chug pretty good (may foul out spark plugs a bit but they get changed every spring anyway)
6. Actually pulled the spark plugs out and put a few drops of oil down the cylinder
7. Chain lube
8. Wash & Wax
9. On the front and rear stand
10. Nice n tight bike cover
Night Night!!
In all actual reality, that is my norm, besides the oil drops.....I have at times, not pulled my battery out (knowing it was junk and replacing it in the spring). I have also, parked it before with slightly used oil in it (like 1 month old & barely any riding)...
Let's hear it guys/gals...
post #2 of 20 (permalink) Old 11-28-2004, 10:50 AM
Winterize? What's that? I ride year-round.
post #3 of 20 (permalink) Old 11-28-2004, 11:07 AM
we need to preface this thread with, all you year-round riders need not post in here..cuz you suck !!
Ive been putting it off, but it'll be done by the end of december. All Im doing is pulling the battery, putting her on the center stand, and a chalk under the front (since I dont have "official front n rear stands", change the oil/filter, full tank of 94 octane & stabil, lube the chain, wash n wax, and most likely pull the plugs like everyother year, but because they are brand new, as in just put them in about 2 months ago, I might just leave them in..havent decided yet.
Need4Speed is offline
post #4 of 20 (permalink) Old 11-28-2004, 11:27 AM
You would have to say that.
Just change oil/filter. Will filler her up and add stabil. Will not be pulling battery since I am going to be starting her twice a week to let her know that I have not forgotten her and miss her. Looking into a set of stands as well. Wash and wax.
GSXR1000DJ is offline
post #5 of 20 (permalink) Old 11-28-2004, 12:04 PM
Do you guys keep your bikes outside during the winter or inside a garage, etc.? If your bike is inside...don't bother taking the battery out. Get a battery tender. It's about 25 bucks for the smallest one and it's what we recommend to our customers. All of our street bikes get hooked up to one in the winter. Let's put it this way, we recommend them so highly, I did a product spotlight for them on our site.
http://www.speedwerks.com/spotlight/m92
Just a thought for ya'.
SpeedWerks.com is offline
post #6 of 20 (permalink) Old 11-28-2004, 12:18 PM
She will also be in a garage as well.
post #7 of 20 (permalink) Old 11-28-2004, 12:27 PM Thread Starter
Oh, yeah I use a small battery tender on my bike all year around. I highly recomend one!!!
N4S, chalk the front?????
Shan...you suck...
Stands, are the best! Once you get a set, you'll never want to be with out them!
post #8 of 20 (permalink) Old 11-28-2004, 03:20 PM
I just but on warmer clothes.
Big Kahuna is offline
post #9 of 20 (permalink) Old 11-28-2004, 03:22 PM
LOL you would out there in Cali.
post #10 of 20 (permalink) Old 11-28-2004, 04:02 PM
Shan...you suck...
Since I have a center stand, that keeps the rear tire off the ground, but the front rests on the cold ground all year long, so I put a small block of wood under the front tire or I'll bunch up a nice thick towel, to keep the front wheel off the cold cement..and then I'll rotate it regularly to keep ti from cupping. quite resourceful if u ask me. !
post #11 of 20 (permalink) Old 11-28-2004, 04:27 PM
Me TOO!!
I zip the goretex liner into my riding jacket and I wear my full leather gloves instead of 1/2 fingers
post #12 of 20 (permalink) Old 11-28-2004, 04:46 PM
Okay, okay! While I don't completely stop riding, I do slow down.... a lot. I actually add gas stabilizer (just bought some today). I could go a few weeks between rides, so I need to make sure the fuel isn't all gummy.
I guess that's what we call Alabama winterizing.
post #13 of 20 (permalink) Old 11-28-2004, 10:05 PM
Don't do that unless you are going to be able to ride it long enough to get up to full operating temperature. By just starting it and letting it run for a few minutes, you get condensation and other contaminants in the oil. The bike needs to be ridden so it is good and hot to burn these off.
It really is better to put it away properly and leave it until you are ready to ride again.
BTW - I think N4S meant to use "chock" instead of "chalk"
post #14 of 20 (permalink) Old 11-28-2004, 10:32 PM
ur right larry..sorry bout that typo...
plus, starting it up every now and then would also drain down ur battery, and if done consistently thru out all the winter months, that could cause undue battery wear, correct ?
post #15 of 20 (permalink) Old 11-29-2004, 12:03 AM Thread Starter
I've heard that before as well Larry, but wasn't going to say anything....
post #16 of 20 (permalink) Old 11-29-2004, 03:59 PM
Will just store it and use battery tender over the winter. Thanks Larryg.
post #17 of 20 (permalink) Old 11-30-2004, 12:19 AM
Actually, cycling the battery is healthy for it as long as it regains full charge each time. If he insisted on starting and idling the bike, it would probably still need a battery tender to help it recover fully between starts.
post #18 of 20 (permalink) Old 11-30-2004, 01:42 AM Thread Starter
Battery Tenders ROCK!!!!
post #19 of 20 (permalink) Old 12-02-2004, 01:19 PM
The battery won't charge unless the bike is above 3000 RPM. So if you're going to just idle your bike every now and then during the winter, you'll need a tender for sure. Trust me.
post #20 of 20 (permalink) Old 12-02-2004, 05:07 PM
To winterize I usually drink mass quantities of tequila and talk alot of *****.. Oh you meant the bike.. Pull it into the garage, put in stabil and call it good.
Mudpuppy is offline
