do you have compression and fuel to the other 3? have you verified spark at the plugs? a motor requires 4 things to run. fuel, air, spark and compression.
well, start with the inexpensive stuff, plugs first, on all four cylinders, test your plug wires on both ends (bad wire is possible) and report back to us. bad plugs are totally possible.
Further, I thought you said you only had a problem with #2. But then you say no sparky on anything but #2???? :scratch:
Most likely there are one to three things wrong. Plugs, wires, or coil pack. Maybe something in the ignition PC but probably not. Which brings up a VERY important question..
What mods? Power Commander?
Related Threads
Two Wheel Forums
509.5K posts
57.9K members
Since 2004
A forum community dedicated to Motorcycle and Sportbike owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
