98 gixer 600 ? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 6 (permalink) Old 07-10-2007, 01:10 PM Thread Starter
98 gixer 600 ?
Have a track bike not charging local shop bench tested my V-regulator=ok still not charging any body have a shop manual for some specs?
ace1 is offline
post #2 of 6 (permalink) Old 07-10-2007, 01:47 PM
Hooked on phonics....
post #3 of 6 (permalink) Old 07-10-2007, 05:26 PM
I have a track bike that does not seem to be charging the battery. A local shop bench tested my V-regulator, it tests ok, but it's still not charging. Does anybody have a shop manual for some specs?
There... fixed, I think.
Kinda hard to find a shop manual and or specs when you don't know year/make/model of the bike.
post #4 of 6 (permalink) Old 07-10-2007, 05:31 PM
it's a wonder what some grammar and punctuation can do!!!
The title of the post says 1998 gixxer 600...
post #5 of 6 (permalink) Old 07-10-2007, 05:33 PM
what is the voltage output at idle and again at 5k RPM?
it could be a bad battery...
post #6 of 6 (permalink) Old 07-10-2007, 06:31 PM
That's right. Set your $10 digital voltmeter to DC volts and read the battery voltage without the engine running. Should be over 12 volts. If not charge the battery. Now read the voltage at 5K. Should be around 14. If over 16, the voltage regulator may be bad, but you'll have to see the specs for your bike. Basically, the voltage regulator changes excess voltage to heat, and the rectifier changes alternating current to direct current. If the voltage doesn't increase from idle to 5K, or worse goes down, the alternator, rectifier, battery, or wiring or all four could be bad.
