How long does it take to get flat spots on tires? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 19 (permalink) Old 11-29-2004, 08:54 PM Thread Starter
Title says it all. Is ti weeks, months or does it depend on the tire? Also, I heard that if you inflat them to +10psi over the recommend, that is a good substitute for a bike stand if you don't have one.
post #2 of 19 (permalink) Old 11-29-2004, 09:01 PM
never did the overinflate thing before..hhhmmmm, interesting.. but I usually rotate the tires periodically, like once a week or so, when its winterized to help that cause.
Need4Speed is offline
post #3 of 19 (permalink) Old 11-29-2004, 09:04 PM
WOW...inflat them to +10psi over the recommend...Never heard of that before but sounds good. I am in the process right now as we speak of getting a pair of Mad Standz from Speedwerks. hehehe I amy not need to overinflat.
GSXR1000DJ is offline
post #4 of 19 (permalink) Old 11-29-2004, 09:27 PM
On the race bikes never..... but the 1k gets them do to the rider doing wheelies a great deal....
post #5 of 19 (permalink) Old 11-30-2004, 12:04 AM
You should keep at least the correct tire pressure in there...FWIW, I worked at a shop that stored lots of bikes for the winter, we didn't do anything for the tires other than set correct pressures when we put them away and never had problems with flat spots.
post #6 of 19 (permalink) Old 11-30-2004, 12:55 AM
When you don't ride with WOS you will get one big flat spot all the way around your tire! Then WOS will laugh at you!!
O, wait, you're talkin about a different type of flat spot!! I'm with Larry on this, set the press and then at least pull it up on a piece of wood! However, there is no substitute for stands!!!!
post #7 of 19 (permalink) Old 11-30-2004, 06:28 AM
I use bike sands for my fleet, That reminds me I need to pick up a new stand today...
post #8 of 19 (permalink) Old 11-30-2004, 02:52 PM
Talking
Bike sand....
post #9 of 19 (permalink) Old 11-30-2004, 03:16 PM
Sure there is...RIDE YOUR BIKE DAILY!!!!!!! Oh yeah, I forgot... Hey Twisty, How's the weather today?...It's 74 and Sunny here...Leaving work in 20 minutes to go for a ride!!!
post #10 of 19 (permalink) Old 11-30-2004, 03:16 PM Thread Starter
Bike sand....
You know, the stuff that lines tracks to slow you down when you go off the track?
post #11 of 19 (permalink) Old 11-30-2004, 04:11 PM
AGAIN AGAIN!! Bee YOU SUCK!!!
post #12 of 19 (permalink) Old 11-30-2004, 07:35 PM
And it is gonna be a long winter for the WOS gang from the Great Lake State. Be glad I don't have your telephone number, I've been known to call father-in-law (rides a VTX 1800) and laugh uncontrollably at 2:00 am while Des Moines gets one of their 50mph wind blowing 8 inches of snow storms! Hey wait...I still have Twisty programmed into my phone from Biketoberfest in Daytona......
post #13 of 19 (permalink) Old 11-30-2004, 09:23 PM
I will hunt you down and scalp you...No big deal. I have heal from my racing injuries anyway....
post #14 of 19 (permalink) Old 11-30-2004, 09:55 PM
Twisty, call me, I'll drive down there with ya!! Look out Bee, you keep this up and we're coming for you!!!
post #15 of 19 (permalink) Old 12-01-2004, 08:05 PM
Yeah well don't forget to bring your bikes, pack a lunch and bring me a WOS sticker for the back window of my truck...
post #16 of 19 (permalink) Old 12-01-2004, 08:17 PM
I've read in places this whole tire thing is an old wives' tale at least in the context of a winter.
kanwisch is offline
post #17 of 19 (permalink) Old 12-02-2004, 01:36 PM
Yes, over inflating you tires will help stay off the flat spots if you can't get them off the ground. Make sure you deflate the tires before you ride though.
Not sure how long it takes to develope the flat spots as I've never ever seen them on my bikes.
Also, check you gauge against others from time to time as my gauge was off by +10psi and I didn't know it till months and months later.
Big Kahuna is offline
post #18 of 19 (permalink) Old 12-09-2004, 10:10 PM
flat center
its hard not to get a flat center when u commute on the bike and dont even start your cage for 4 months. when u live in the city and theres traffic u cant spend too much time on the edges...only time i get enough room to go over 30 is when i hit a straight away and split cars... or the occasional empty street.
Not enough corners in the city of Reno to use the sides, i guess if i didnt run a BT14 it wouldnt be so big... have to go dual compound next time not all soft ass butter tread.
ScottSellersUNR is offline
post #19 of 19 (permalink) Old 01-20-2005, 10:50 AM
i agree, ive had many many bikes in the garage for many winters on all types of tires and never ever had a flat spot on any of them. fill em up to correct psi and wait for the warm weather.
if your garage has a concrete floor it is a good idea to put a piece of wood or carpet under the tires , concrete does something to the rubber (faster dry rot etc) but again i never did, and i never had tires on the bike that lasted long enough to worry about it...but it its a daily cruiser, id put something under the tires...
GsxrJack is offline
