Tire size? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 16 (permalink) Old 07-23-2007, 11:02 AM Thread Starter
Tire size?
I have a 01 Gixxer 750 and its getting to be that time to get a new rear tire..... The stock size is a 180 55 ZR17 and I am getting a 190 50 ZR17 tire.... The reason I am putting a different sized tire is this... My buddy bought this tire a couple years ago and he has since totaled his bike and has nothing to put it on so he is giving it to me for cheap money.... Now will putting a wider tire out back adversly effect handling and if so how bad...
post #2 of 16 (permalink) Old 07-23-2007, 11:04 AM
It will affect the handling, it will be a bit harder to dip it into a turn. My stock tire was a 190, I put a 180 on it...now it's just begging for the twisties.
devilstonic is offline
post #3 of 16 (permalink) Old 07-23-2007, 11:06 AM
Yes, you will not corner as well and with the extra weight of the 190 tire you will be down on power. Probably not enough to notice though.
post #4 of 16 (permalink) Old 07-23-2007, 11:26 AM Thread Starter
Will it effect cornering noticibly.... I dont consider myself an aggressive rider meaning i dont track my bike or drag knee I do lean it over but I dont utilize all of the tire... my tire on it now I use all of the tire with exception of a 1/4" on both sides.
post #5 of 16 (permalink) Old 07-23-2007, 11:32 AM
1/4"? Thats better than most. I'd stick with a 180 if it was me, but tires dont last long and if you can get it super cheap. give it a shot.
post #6 of 16 (permalink) Old 07-23-2007, 11:38 AM Thread Starter
i am getting this tire for 60 bucks
so i figured i should just put it on
post #7 of 16 (permalink) Old 07-23-2007, 11:41 AM
Good deal!
post #8 of 16 (permalink) Old 07-23-2007, 11:43 AM
I'd stick with a 180 but thats me I heard it affects handling too much.
post #9 of 16 (permalink) Old 07-23-2007, 11:49 AM
Everyone that I know that has gone 190 after riding 180, go right back to 180. However, we all ride twisties all the time, so cornering is a big deal to us. From what I have been told with a 190 it's a lot harder to get the bike to come over entering and the 180 feels like it just wants to dive in the corner.
post #10 of 16 (permalink) Old 07-23-2007, 03:51 PM Thread Starter
If a 190 tire adversely effects handling then why do they put them on all the liter bikes? What positives does a 190 tire ad that would out weigh the handling issue? I am only putting the bigger tire on because I am getting it for dirt cheap. but i am just curious.
post #11 of 16 (permalink) Old 07-23-2007, 03:58 PM
Amen!
post #12 of 16 (permalink) Old 07-23-2007, 04:22 PM
rim size makes a dif too...most 600's come with a 5.5 inch rim, and usually liters have a 6incher
for awhile the 750's came with 190's
you're not draggin a knee, so i doubt you'll notice anything
however, if the tire is really old, it may not be worth it, even though its "new"
dnyce is offline
post #13 of 16 (permalink) Old 07-23-2007, 06:57 PM
it weighs more hence they are tryin to slow the insanely fast things down 8)
post #14 of 16 (permalink) Old 07-24-2007, 02:25 PM Thread Starter
How much more could it possibly weigh couple ounces... honestly it cant ad more than a pound
post #15 of 16 (permalink) Old 07-24-2007, 02:32 PM
I went from a 190 down to a 180, I don't think I had it on but a month and I had to switch back to the 190. I hated the 180 and couldn't get use to it.
Will your 750cc allow a 190 on the stock wheel and swing arm clearence?
post #16 of 16 (permalink) Old 07-24-2007, 03:02 PM
with fatter rear tires, if the bike doesn't want to fall into corners like before, raise the rear ride height. also, over inflate + 5 psi from recommended. fatter rear will give a larger contact patch at full lean but will add to rotating mass (weight).
take note of the clearance. make sure nothing is rubbing on it.
