Bike went DEAD - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 11 (permalink) Old 07-23-2007, 03:14 PM Thread Starter
Bike went DEAD
I was riding OK yesterday, and I had to pull over to make a phone call. I was sitting there in N with my bike idiling, but when I put it in gear to take off the bike went dead. When I tried to start it the battery seem tobe drained. A Bro of mine was near came a gave me a jump, but when I got to the next light it went dead again. He happen tobe following ,and gave me another jump. Did OK on the way home, but was just wondering what it could have been.
bodydoc is offline
post #2 of 11 (permalink) Old 07-23-2007, 03:22 PM
whats your battery voltage at? I'd charge it and see if it happens again.
post #3 of 11 (permalink) Old 07-23-2007, 05:55 PM
Just a thought, have you made sure your battery connections are nice and tight? I had a problem with my last bike doing the same thing when one of my connections came loose. I screwed it back on tight and things were okay after that
bikergal is offline
post #4 of 11 (permalink) Old 07-23-2007, 09:16 PM
Off topic, but do you or your bud normally carry jumper cables on your bike???
post #5 of 11 (permalink) Old 07-23-2007, 10:07 PM
Or possibly the rectifier may be done or dieing.
jnn7404 is offline
post #6 of 11 (permalink) Old 07-23-2007, 11:24 PM
last time that happen to me i ended up getting a new battery.
elimental is offline
post #7 of 11 (permalink) Old 07-24-2007, 01:53 AM
What is the sitting voltage of the bike? Should be 12.8 or so.
And also check the connections.
Get back to us.
post #8 of 11 (permalink) Old 07-24-2007, 02:30 PM Thread Starter
Vots are reading about 11. something A bro of mine hooked it up to a vot meter. Its the regulator now Ive been shopping around for one. Thanks for all the input.
bodydoc is offline
post #9 of 11 (permalink) Old 07-24-2007, 02:48 PM
post #10 of 11 (permalink) Old 07-24-2007, 08:48 PM
Well charge the battery and then see if it will hold.
post #11 of 11 (permalink) Old 07-26-2007, 09:42 PM
Well, it sounds like your battery is on it's last leg. Try charging it and seeing how it does. As far as the bike dieing goes, that is not caused by a dead battery. I'm pretty positive it doesn't work that way.
How did it die? Any lights come on, if you have any? Any odd noises when you got it running again? Will it idle at all right now without dieing? Any sputtering?
A loose connection could be the cause, or your bike might need a tune up or a carb rebuild. It really depends on what else is happening.
brie is offline
