06 zx6r valve adjusting - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 07-25-2007, 02:43 AM Thread Starter
i need my valves adjusted.can i do it myself,if so how hard is it gonna be and what all do i need?
XxJIMMYxX is offline
post #2 of 7 (permalink) Old 07-25-2007, 02:55 AM
You guys and your valve adjustments, chain lubing, etc...
Take it to the shop, unless you have someone around you that knows A LOT about new bike tech...
post #3 of 7 (permalink) Old 07-25-2007, 08:49 AM
An 06 and you want to do a valve adjustment already? How many miles do you have?
post #4 of 7 (permalink) Old 07-25-2007, 02:19 PM Thread Starter
believe it or not jus over 17,ooo miles i got it last may.
post #5 of 7 (permalink) Old 07-25-2007, 02:25 PM
Ride on, dude.
post #6 of 7 (permalink) Old 07-25-2007, 02:50 PM
if it's still under warranty, have the dealer do it. i assume it'a shim under buck type adjustment. you will need the correct shim replacement.
post #7 of 7 (permalink) Old 07-26-2007, 12:20 AM
It's not hard to check the valves. It's actually fun to see what goes on under the valve cover. Probably just need a shop manual, feeler gauge, and wrench to turn the engine. With the engine cold, turn it to TDC on the compression stroke (with the spark plugs out, the compression will push on your palm over No. 1 sparkplug hole), check the valves that the manual tells you to check. Write down the readings in your manual. Then turn the engine the way the manual says and check the next ones. When you finish, see if any are out of specs. Hopefully, none will be. Otherwise you have to take the cams out. If you check them you will probably need to replace the valve cover gasket.
