Adjusting shifter lever for more room for boot? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 12 (permalink) Old 07-27-2007, 02:42 PM Thread Starter
I took my Ninja 250 out last night with my new Alpinestars SMX-4 and I had a little trouble shifting because it felt like the boot was not fitting under the shifter well. I also downshifted on accident a couple of times because my boot hit the shifter down when I was trying to get the boot under it. Can I adjust the shifter to make more room? If so is there a certain amount of room I am supposed to have?
Thanks!
Danase is offline
post #2 of 12 (permalink) Old 07-27-2007, 02:50 PM
I'd be interested to know the answer to that question too.
Becca_007 is offline
post #3 of 12 (permalink) Old 07-27-2007, 02:51 PM
post #4 of 12 (permalink) Old 07-27-2007, 02:53 PM
I can show you on your bike. The 250, I have no idea how to do it. Might be the same but I cant say for sure.
post #5 of 12 (permalink) Old 07-27-2007, 03:18 PM Thread Starter
Thanks Crazy! I looked but did not see it on that site. I need to open my eyes more I think.
Danase is offline
post #6 of 12 (permalink) Old 07-27-2007, 03:39 PM
I never gave it much thought til I saw this thread but with my boots on it's a lil tight. That and my new stands are supposed to arrive today so I have to come up with things to do!
post #7 of 12 (permalink) Old 07-27-2007, 03:56 PM Thread Starter
I looked and it looks like your adjustment is identical to mine so you should be able to adjust yours per the 250 direction above.
Danase is offline
post #8 of 12 (permalink) Old 07-27-2007, 06:10 PM
I think most bikes are adjusted that way (whether it's vertical or horizontal). My 650R however does not have the link rod.
Got Gear?
post #9 of 12 (permalink) Old 07-27-2007, 10:20 PM
Many are splined. You mark where it is, take off the shifter, rotate it up or down one spline, and reinstall. But that just changes the angle of the shifter. I think you need a longer shifter to get your foot underneath. I forget what years it is, and I'll look it up if anyone's interested, but the R1's and FZ1's shifting can be improved by changing to a different length shifter.
post #10 of 12 (permalink) Old 07-27-2007, 10:57 PM
If it is primarily caused by your new boots, I would leave it alone for a bit. Be carefull but leave it. Most likely once the boots break in you won't have the problem.
post #11 of 12 (permalink) Old 07-28-2007, 11:11 AM
I adjusted mine up for GP shift. Needed to fit my boot under it for downshifts. Pretty easy. Not sure how the 250's are set up though.
post #12 of 12 (permalink) Old 07-28-2007, 11:18 AM
makes me wonder why manufacturers didn't set it up that way from the factory. reverse pattern seems to be easier to shift through corners. i can never go to that GP setup though. normal shift patterns has done integrated into my one-ness with the bike. if i switched to reverse pattern, i'll feel like a newb again.
