04 zx10r whistling sound - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 6 (permalink) Old 08-03-2007, 10:25 PM Thread Starter
dom
anybody with a 04 zx10r Im getting a whistling sound, does anybody have the same problem with there zx10. can it be fixed.
dom is offline
post #2 of 6 (permalink) Old 08-03-2007, 11:26 PM
PiZdETS's Avatar
When you're going ludicrous speeds on a literbike the air is moving extremely quickly over your bike and helmet, this may cause the whistling noise you're experiencing.
It could also be the sound of sirens rapidly fading behind you.
Nice bike,
Patience is something you admire in the driver behind you and scorn in the one ahead. ~Mac McCleary
PiZdETS is offline
post #3 of 6 (permalink) Old 08-03-2007, 11:30 PM
Intake?
post #4 of 6 (permalink) Old 08-03-2007, 11:46 PM
Intake?
If it's from the engine, there's an air leak. Either one or more of the boots on the engine side of the injectors is leaking, or one of the plugs for synchronizing the injectors fell off.
post #5 of 6 (permalink) Old 08-04-2007, 11:51 PM
in any case, FIX IT NOW. air leaks make motors run lean, which can lead to premature and COMPLETE failure of your motor. find whats making the noise, if its an air leak, dont waste time fix it before you get a holy but not righteous piston.
post #6 of 6 (permalink) Old 08-05-2007, 06:48 AM
An easy way to find any type of air leak...whether it be at the air intake or whereever... just spray some brake cleaner (can use WD40 but the BC is cleaner) at the gaskets with the motor running. If the idle speed picks up.. that's your leak!
