Just bought first sportbike GSXR1100 - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 20 (permalink) Old 08-05-2007, 03:53 PM Thread Starter
I recently purchased my first sportbike. Absolutely love it. I have been having problems with the battery recharging. I can ride for about 1/2 hour before it dies. Plan to take it to the dealer to get it onced over and find the problem. Also have power loss in first gear. At take off, if i try to get on it, it will spit for a sec then go. was wondering if this is something i can fix myself? Have been also looking for mods and websites for aftermarket parts for my bike and keep coming up short. Is there a company out there that has parts for my bike, or is it just too old?
jaye_1224 is offline
post #2 of 20 (permalink) Old 08-05-2007, 07:02 PM
A old school 1100 or a newer 1000? Either way that is alot of bike for a first one. I sure hope its just first sportbike and you have more years on something else.
On the charging system...
First, will the battery take a charge? What is its standing voltage after say 12 hrs of sitting? Needs to be 12.8.
Second, what is the voltage with the bike running and say at 4,500 rpms? Should be in the high 13's.
Report back...
post #3 of 20 (permalink) Old 08-05-2007, 07:14 PM
with gasman on the charging prob
sounds like a old skool 1100- as far as the power loss, check the carbs, could need a rebuild or just a cleaning- what year is it, i know a few of em had a ignition thing that killed power in first gear i think, maybe its acting up. to disable it u just cut a wire i believe. do alil research, lots of companies made stuff for it, what direction do you want to go in (drag, canyon carver, or just upgrade some stuff and custom paint), and we can help you out.
dnyce is offline
post #4 of 20 (permalink) Old 08-05-2007, 07:40 PM
n it could be cutting out n spitting from a bad battery.
post #5 of 20 (permalink) Old 08-05-2007, 08:18 PM
Buy a Buell.
post #6 of 20 (permalink) Old 08-06-2007, 07:17 AM Thread Starter
battery holds charge. at 4500 rpm it read in the low tens. not first bike been riding for years. old school 97 gsx-r 1100
post #7 of 20 (permalink) Old 08-06-2007, 07:20 AM
low tens? somethins puttin a massive drain on that thing- u check all the wires?
dnyce is offline
post #8 of 20 (permalink) Old 08-06-2007, 07:26 AM Thread Starter
just few upgrades, some paint. as far as i can tell so far the bike is still stock. don't want to dump too much into it. In a year ot two i will be looking at a new busa. I sat on a buell when i was shopping and found this gixxer. That was the most unconfortable bike. test drove many sport bikes b4 i found mine. As far as comfort and speed, the gixxer is the one for me.
post #9 of 20 (permalink) Old 08-06-2007, 11:57 AM
The 11's are sick bikes.
post #10 of 20 (permalink) Old 08-06-2007, 11:57 AM
Short circuit or bad voltage regulator/stator. Hope it's just a short in a light or old insulation rubbing through.
Got Gear?
post #11 of 20 (permalink) Old 08-06-2007, 02:26 PM
Low tens???
That battery should read 12.8 sitting with the bike off. It should hold that for weeks.
With the bike running at 4.5K it should show 13.8 - 14.2 volts.
I'm willing to bet the battery is junk. Try putting it on a trickle/slow 2amp or less charge. Get it back to full power. See if it will hold that charge for a day. Remember 12.8 volts. Then if it does... put it in the bike.
Then start the bike and check for that 4.5rpms / 14.0 volts. If it doesn't do that... then you are going to have to look into the stator or Voltage regulator.
You can read up on the stator/VR trouble shooting in this past thread HERE I gave a good break down on how to start checking.
post #12 of 20 (permalink) Old 08-06-2007, 04:19 PM
dnyce is offline
post #13 of 20 (permalink) Old 08-07-2007, 05:34 PM Thread Starter
Low tens???
i will give that a shot. Thanks for the help man. Really miss riding my bike. hope it ends up being something small. i seen a new generator is almost $700.
post #14 of 20 (permalink) Old 08-07-2007, 05:36 PM Thread Starter
i checked out the website. they only have parts for the 88-92 gixxer 1100
post #15 of 20 (permalink) Old 08-07-2007, 06:12 PM Thread Starter
haven't checked all the wires. the battery to the generator, couple of fuses. been so frustrated about not being able to ride i put it all back together just to ride a half hour around town. going to tear it down tonight, again. I have till tuesday to fix it b4 i take it to the dealer and get screwed for $58 an hour!
post #16 of 20 (permalink) Old 08-08-2007, 12:27 AM
oh, those were just some pics-i wasnt suggesting that site, i never even checked it
dnyce is offline
post #17 of 20 (permalink) Old 08-08-2007, 08:14 PM Thread Starter
Low tens???
i charged the battery. It held at 12.7 for a day. So i put it into bike as soon as i turned key over it read 11.6. Started the bike, running at 4500 it still read 11.6. Guees its getting into the expensive part now
post #18 of 20 (permalink) Old 08-08-2007, 11:33 PM
I am thinking you have a bad stator or VR. This is where owning a service manual comes in hand. If you did, it would tell you how to diagnose the parts. Checking each piece isn't hard! Then you could just buy the replacement.
Not that I always recommend this, espeically for electrical parts... but check ebay. You might catch a good deal.
post #19 of 20 (permalink) Old 08-10-2007, 05:44 PM Thread Starter
I have the service manual. I have to go and buy more tools, which is not always a bad thing. After reading the steps i got alittle discouraged. Think I will take the hit of a professional. the bike needs tuned and onced over anyways. Thanks for all your help.
post #20 of 20 (permalink) Old 08-10-2007, 11:53 PM
Do what you must... I know electrical is a hard thing to get sometimes. It is for me too. But if you read my thread I linked along with your manual, I bet you could get it. Just put it on your nightstand or in the bathroom. Which ever fits you, read up, then go out and test it. You'll feel better about you and your bike.
Besides, the mechanic don't give 2 rats a$$ about your bike. Nobody will care for it like you will. That I can gaurentee!
