sv650 starting problems - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 13 (permalink) Old 08-06-2007, 01:03 AM Thread Starter
sorry not sure if this is the write place to post this..... i posted the same exact thing on sv650.org... but seems nobody knows whats up..or maybe its just the time zone difference between countries
ok ok .. you guys have seen ive been havin problems with the sv650.. today i had to start the sv by constantly pushing hitting the ignition switch click/click/click/click then it would finally cut on ..
today at the gas station..after i filled up.. i would hit the ignition click / click /click...click... and then it just kept rolling the engine over... i even took the keys out and the ignition kept rolling over and over and over by itself without me pushing anything..sounded like it may have been firing on one cylinder.... then i hit the ignition one more time..click..and it fired right up....
drove it home...and now she wont start at all ... i hit the ignition..and it sounded like she wanted to roll / click / click /click.. still nothing.. i check the battery out with a voltmeter and she is good to go....
we also took a hammer to the starter gave it a few clunks...
i check all the fuses i could think of.. but now its nothing but click click click... click click click x 20 ...
tampa2wheels is offline
post #2 of 13 (permalink) Old 08-06-2007, 03:12 PM
Fuel injected SV?
post #3 of 13 (permalink) Old 08-06-2007, 07:31 PM Thread Starter
Fuel injected SV?
carburated
post #4 of 13 (permalink) Old 08-06-2007, 11:27 PM
You say the battery is good. How do you know? What is the voltage after the bike has been sitting? Needs to be 12.8.
Where is this "click" coming from?
post #5 of 13 (permalink) Old 08-07-2007, 02:29 AM
At the moment I'm not sure how to help with this problem but I'm curious, was the bike new or used when you got it?
brie is offline
post #6 of 13 (permalink) Old 08-08-2007, 09:21 AM
my thought is are all the electrical connections clean and tight like they should be?
post #7 of 13 (permalink) Old 08-09-2007, 02:53 AM
Could be carbs?
It's always easier to diagnose a problem when you're there...
brie is offline
post #8 of 13 (permalink) Old 08-09-2007, 02:06 PM
Is the clicking coming from the starter solenoid? If it is, that means power is getting to it. But is it enough power? If you have a digital voltmeter, the battery should be 13 volts or higher. Charge it for a day if not, then try it again.
post #9 of 13 (permalink) Old 08-10-2007, 09:25 AM
Ive got a 2000 sv650 that had similar problems. Check your Regulator Rectifier and your battery. I would replace your battery if its the stock one. by replacing the battery in my sv that fixed i also replaced my Regulator Rectifier as well a while later due to charging problems but the battery alone fixed the starting up problem. If you have another bike or a friend willing to come let you borrow there battery thatís what I did. I took my battery out of my gsxr and put it in the sv and the sv battery was in my gsxr, everything worked fine my gsxr was struggling to start up after sitting for more then an hour after riding it for more than 30 minutes more than enough time to charge the battery well.
DCMoney is offline
post #10 of 13 (permalink) Old 08-10-2007, 11:45 PM
Is this a post n run?
post #11 of 13 (permalink) Old 08-11-2007, 12:22 AM
26 posts... then run?
post #12 of 13 (permalink) Old 08-14-2007, 01:59 PM Thread Starter
nah im back.. sorry.. was been hella busy... i checked all the connection.. tried to jumpstart with car... but that did not work...it could just be the battery... i gave the bike back to the owner today...
i think its the starter personally but the engine wont turn anymore
post #13 of 13 (permalink) Old 08-14-2007, 05:02 PM
Gave back to the owner? How did you swing that?
