need help - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 10 (permalink) Old 08-08-2007, 12:02 AM Thread Starter
need help
I have a 93 900rr my questions is the neutral light stays on while I go through all the gears.....no bad shifting....don't really know why...?
rcee14 is offline
post #2 of 10 (permalink) Old 08-08-2007, 08:48 PM
sounds to me like a shorted or a bare wire to the neutral light
warp speed warrior is offline
post #3 of 10 (permalink) Old 08-08-2007, 09:01 PM
Or just a bad neutral switch?
jnn7404 is offline
post #4 of 10 (permalink) Old 08-08-2007, 09:02 PM
I wouldn't worry with it as long as you know where neutral is and don't mind a green light!
jnn7404 is offline
post #5 of 10 (permalink) Old 08-08-2007, 09:14 PM
True Dat true dat
just throwin in my
post #6 of 10 (permalink) Old 08-08-2007, 09:19 PM
Im no mechanic just past experiences. Just cause i dont think its the kickstand doesn't mean its not! Didn't mean to sound like that.
jnn7404 is offline
post #7 of 10 (permalink) Old 08-08-2007, 09:24 PM
No offense taken Bro
post #8 of 10 (permalink) Old 08-08-2007, 11:34 PM
Nuetral light comes on even when not in nuetral. Either replace the switch or remove the bulb.
post #9 of 10 (permalink) Old 08-08-2007, 11:36 PM
jnn7404 is offline
post #10 of 10 (permalink) Old 08-09-2007, 12:10 AM
It's easy to test the switch, you just have to find it. Most neutral switches are on the bottom or sides of the crankcase. Check your manual and wire diagram. Disconnect the wire on the neutral switch from the main loom of wires, and check for continuity between the wire and ground. There should be continuity when the trans is in neutral, and high resistance when in gear. If not, the switch is bad and has to be replaced.
