spark plugs - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 10 (permalink) Old 08-20-2007, 07:38 PM Thread Starter
spark plugs
ok so i have a 96 cbr600 f3 and i am changing the spark plugs. got 3 of 4 in but the 4th wont go back in for some reason. im not sure why. anyone know what to do?
corteztk1982 is offline
post #2 of 10 (permalink) Old 08-20-2007, 07:52 PM
Spark plug
Look at the threads on all of the plugs you remove where they clean? Was the one that came out of that "HOLE" hard to get out? Did the store give you three of one plug and one of another??
Just some ideas.....
If all else fails you may have to use a thread restorer.....
RacerRobb is offline
post #3 of 10 (permalink) Old 08-20-2007, 09:14 PM
are you sure you're threading the plug in straight? everything matching plug wise?
post #4 of 10 (permalink) Old 08-20-2007, 09:21 PM
I've always called it a thread chaser. Probably find it at Checker Auto, Auto Zone, or such. It's like a tap from a tap and die that cleans out the spark plug thread in the head. I think for your Honda it should be 12mm, but bring a spark plug to be sure.
post #5 of 10 (permalink) Old 08-20-2007, 10:38 PM
Doesn't that drop chit into the cyclinder?
post #6 of 10 (permalink) Old 08-20-2007, 11:25 PM
I was thinking that myself. its something that scares me about repairing threads while the head is still on the motor. metal shards in the cylinder=rebuild real fast.
post #7 of 10 (permalink) Old 08-21-2007, 07:36 AM
I would do as said, and inspect the old plugs threads. But further, be sure to make sure you are screwing it in correctly. It might have to go in straight but it could also go in not straight.
post #8 of 10 (permalink) Old 08-21-2007, 07:38 AM
threads in heads..
Apply some bearing grease to the thread chaser. Dont not run it all the way in. just go 1/2 to 3/4 turn then back out clean apply more grease and repeat.
The grease will catch the threads.
be careful not to run the thread chaser beyond the threads or you will have one hell of a time getting it out.
Unfortunately I just had to do this to the rear cylinder on my 2004 Yamaha Roadstar Warrior.
It works just be careful....
post #9 of 10 (permalink) Old 08-21-2007, 07:41 AM
Plug size
Make sure that you get the right size/thread pitch. My Yamaha was a 12/1.25 I believe get the wrong pitch and you'll be right back where you started..
post #10 of 10 (permalink) Old 08-21-2007, 07:49 AM
Yeah if you drop it in... you'll be pulling the head!
