Got my Pitbull stand, only one problem... - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 19 (permalink) Old 08-21-2007, 05:26 PM Thread Starter
The UPS man/woman left this at my door today, and its AWESOME! Sturdy as hell...however, from my last lowside, the spool on the right bent the mount on the swingarm.
I tried to bend it back but it started tearing the metal at the weld so I stopped.
It seems to be strong enough to support the bike on the stand, but has this happened to anyone else? I've never heard of it before
Stan_James is offline
post #2 of 19 (permalink) Old 08-21-2007, 06:33 PM
get a new spool
post #3 of 19 (permalink) Old 08-21-2007, 06:47 PM Thread Starter
get a new spool
lol yeah I should get a new one, but im worried about the damage done to the swingarm...
post #4 of 19 (permalink) Old 08-21-2007, 06:51 PM
kinda looks like the hole for the spool is also bent.
post #5 of 19 (permalink) Old 08-21-2007, 07:32 PM
Find somebody who can TIG weld. Shouldn't take long to cut off the old hole and weld a nut in its place.
Got Gear?
post #6 of 19 (permalink) Old 08-21-2007, 07:41 PM
The only thing is that after you weld there the finish will be all chitty... if you care about that, you'll need to re-powdercoat or something. Maybe you could use some engine paint and do it yourself though.
The other option is to tap holes in your swingarm...
post #7 of 19 (permalink) Old 08-21-2007, 07:56 PM
Or you could just flip the stand holders and not use spools.
post #8 of 19 (permalink) Old 08-21-2007, 07:59 PM
True... a little less stable though if you knock into it or something...
Another thing I just thought of... you said you tried to bend it back but were afraid you might snap it off... well if you used a blowtorch to heat it (or maybe a heat gun) as you tried to bend it you should be able to do so without it separating at all. You just need to get it hot enough to be malleable but not so hot that you melt it or completely ruin the finish.
post #9 of 19 (permalink) Old 08-21-2007, 09:42 PM Thread Starter
lol...shoulda posted on here BEFORE I tried to bend it...oh well...maybe just cut it off and weld a new mount on
I appreciate the different ideas everyone I would rep if I could
post #10 of 19 (permalink) Old 08-21-2007, 09:43 PM Thread Starter
eww...that sounds scary, wonder if anyone has done that
post #11 of 19 (permalink) Old 08-22-2007, 08:02 AM
I can't see the pics with PB being blocked at work... but if there is anything wrong with the stand itself just send it back. If its the bike... without seeing the pics I'm not sure....
post #12 of 19 (permalink) Old 08-22-2007, 08:14 AM
Grafixx01's Avatar
Looks like it to me.
I don't remember seeing holes in my swingarm on my 2005 R6, can't recall. But I have spools/sliders on mine and can just replace the entire thing, or just the puck (Vortex).
I had the dealer put mine on, but that was like two months after I bought the bike. Like I stated above, I don't recall seeing holes pretapped for spools, and it took the dealer like an hour to get them on so I'm guessing they tapped them at the shop and then put the spools on. When I lowsided the bike, it slid and all I did was replace the puck, bolt came right out and wasn't bent at all. I'd look now but the bike is still in the shop.
Grafixx01 is offline
post #13 of 19 (permalink) Old 08-22-2007, 09:20 AM
Stand is fine, he bent the s**t out of tapped hole for the spools.
post #14 of 19 (permalink) Old 08-22-2007, 02:18 PM
Yeah people have, in most bikes it is fine
Good luck figuring it out though.
post #15 of 19 (permalink) Old 08-22-2007, 08:44 PM
That sucks... did you just bend the bolt?
post #16 of 19 (permalink) Old 08-22-2007, 09:04 PM Thread Starter
lol, I wish it would've. The bolt isn't bent at all, its just the where the mount is welded onto the swingarm
post #17 of 19 (permalink) Old 08-22-2007, 09:18 PM
Before I opened this, I said "I bet it's a Kawi". My buddy low-sided his Kawi and the whole mount fell off. He went and bought a new (to him) swingarm off Ebay though. I think he paid like two bills for it. You could always reverse the mounts on the stand and just use the swingarm itself to hold the bike up.
post #18 of 19 (permalink) Old 08-22-2007, 09:51 PM
If you jacked the swingarm, there is only a few options.
One live with it, don't use the spools and flip the pit bull ends and just use the feet like you would if you didn't have spools.
Get a new swingarm and hope it don't happen again.
Have it tig welded and then re-powdercoated. Or after welding it, just paint it. There have been a few members around here that have had good luck with painting these things like swingarms, fork legs and such.
post #19 of 19 (permalink) Old 08-22-2007, 10:41 PM Thread Starter
I believe I'm going to go with option #1, live with it for $200
