Winter Time.. - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 22 (permalink) Old 08-22-2007, 06:46 PM Thread Starter
Winter Time..
During winter when you cant ride how often should you start your bike to keep the charge and everything up on the battery and make sure nothing dries out?? A random question but something i dont know so i asked
MotoCraz is offline
post #2 of 22 (permalink) Old 08-22-2007, 06:47 PM
Buy a battery tender
post #3 of 22 (permalink) Old 08-22-2007, 07:08 PM
but what is this winter/winterzing the bike thing y'all talk about?
ne1469 is offline
post #4 of 22 (permalink) Old 08-22-2007, 07:19 PM
In Nov-Dec. (whenever that b*tch Mother Nature says I can't ride anymore) I fill the tank, run some stabil into the system, pull the battery, put it up on stands front and rear, cover it, and leave it till i'm given permission to ride again.
You suck
post #5 of 22 (permalink) Old 08-22-2007, 07:33 PM
do not start the bike during winter for this reason...
Don't do that unless you are going to be able to ride it long enough to get up to full operating temperature. By just starting it and letting it run for a few minutes, you get condensation and other contaminants in the oil. The bike needs to be ridden so it is good and hot to burn these off.
It really is better to put it away properly and leave it until you are ready to ride again.
gasman's recommended winterization checklist...
Here's what I, myself, do to my bikes before I put them away.
Add stabalizer to gas... ride 10 miles... then home
change oil and filter.
bring motor up to temp
turn off.
wash n wax bike throughly
clean/lube chain
top off gasoline to brim and if it has a petcock turn it to off
check/adjust air pressure in tires
Put in corner on stands. Any tire still touching ground should be on wood.
Cover bike
Pull battery and put on battery tender.
In the spring...
put battery back in bike
get out of corner and uncovered and off stands.
start bike and bring to temp
check for any leaks oil or water
turn off bike
check air pressure in tires
ride bike thru 2 tanks of gas.
change oil and filter again.
replace spark plugs!
Ride it like you stole it!
itgirl25 is offline
post #6 of 22 (permalink) Old 08-22-2007, 09:36 PM
turn off.
clean/lube chain
Cover bike
In the spring...
turn off bike
Yep. There it is.
post #7 of 22 (permalink) Old 08-22-2007, 09:38 PM
Yeah what Itgirl said that I said!!
Battery Tender's are your friend!!
post #8 of 22 (permalink) Old 08-22-2007, 09:39 PM
wait, what?? you mean you quit riding in the winter??
j/k all good info here!
post #9 of 22 (permalink) Old 08-22-2007, 09:40 PM
cant wait for all that bull**** to start again...
post #10 of 22 (permalink) Old 08-22-2007, 10:53 PM
I think I might start banning peeps... starting with Rae!
J/K Rae... you too sexy to ban!
Also moving this to tech.
post #11 of 22 (permalink) Old 08-23-2007, 12:04 PM
You suck too...
but you're hot, so it's ok
post #12 of 22 (permalink) Old 08-23-2007, 12:40 PM
ah the joys of living in Florida
Shift is offline
post #13 of 22 (permalink) Old 08-23-2007, 12:42 PM
You suck too...
yes, very hot , butt thats only for about 3-4 months, after that your bike will be in the garage and we'll be out riding in nice cool weather for the next couple months.
Shift is offline
post #14 of 22 (permalink) Old 08-23-2007, 01:24 PM
I meant Rae was hot
last winter there was never a month that I was didn't get at least 1 mile in.
Dec - Feb were the only months I wasn't riding consistantly.
post #15 of 22 (permalink) Old 08-23-2007, 01:26 PM
trock's Avatar
Send a message via MSN to trock
Pussies, just put on under armour cold gear and ride.
trock is offline
post #16 of 22 (permalink) Old 08-23-2007, 02:44 PM
Thanks guys!!
I ride regardless of temps, beleive it or not it does get chilly here...i rode this winter in about 30 degree minus windchill, thought I was gonna die...
post #17 of 22 (permalink) Old 08-23-2007, 02:48 PM
I ride almost year around, exept for 1 maybe 2 months then for short trips to make surebike doesnt sit to long.
papapoi is offline
post #18 of 22 (permalink) Old 08-23-2007, 02:50 PM Thread Starter
Thanks for all the good info... and i agree Rae is a pretty HOT
MotoCraz is offline
post #19 of 22 (permalink) Old 08-23-2007, 02:55 PM
But she can be a REAL ............Just JOKING. don't kill me next time i'm out LOL
papapoi is offline
post #20 of 22 (permalink) Old 08-23-2007, 03:09 PM
I miss winter time. I would be nice to have a change in seasons.
griffter911 is offline
