Advanced Auto SUX>> - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 17 (permalink) Old 09-16-2007, 07:25 PM Thread Starter
Advanced Auto SUX>>
When you decide to change plugs etc PLAN on getting you parts during the week when your fav bike shop is open. I decided today while cleaning n recharging my K&N airfilter to put in a fresh set of plugs. Well it being sunday no bike shops open, so I call Advanced Auto up and ask if they have the plug my bike calls for. After translating english to the chick on the phone (it was a white chick by the sound of her just tarded.) I drive across town to pick them up, and I didnt take one with me to compare with. I get there, get to the counter, hand the guy a sticky with the part # on it. He brings out a CR9E, and I needed CR9EH 9 (which according to NGK goes in a 1000+ VFR i think it said). So my bike it in pieces til tomorrow when Kirk's opens and I can get the right plugs. And the sucky part is I WANTED TO RIDE TODAY!!!!
post #2 of 17 (permalink) Old 09-16-2007, 07:46 PM
Are you sure they won't work? Mine calls for a cr9e but it interchanges with some other ones. They just don't burn as hot or burns hotter.
jnn7404 is offline
post #3 of 17 (permalink) Old 09-16-2007, 08:30 PM Thread Starter
these they gave are threaded all the way up and the one out of my bike stop bout a 1/4" before the stop. I checked on teh NGK site to see it they would cross over but dont list the cbr at all for these.
post #4 of 17 (permalink) Old 09-16-2007, 08:32 PM
2FURYUS's Avatar
You could always put the old ones back in until tomorrow.
YA THINK???
2FURYUS is offline
post #5 of 17 (permalink) Old 09-16-2007, 08:40 PM Thread Starter
and have to tear it all back down to get to em again??? I just thought my 88 cbr was a pita to change em. I cheated tho. I remove the airbox. I dunno htf they expected a ratchet to get up there from the front.
I had to stop n cook n now its dark so I'll wait til morning n go return these n goto kirk's n get the right ones. K&N is clean n recharged tho
post #6 of 17 (permalink) Old 09-16-2007, 11:01 PM
buy extra plugs so u dont have to go next time. they're usually cheap anyway
Thats what I'd have done... but then on a ninja 250 you can get at the plugs by just pulling off the gas tank...
post #7 of 17 (permalink) Old 09-16-2007, 11:11 PM Thread Starter
cheap? $4 - $10 each no biggy really but just something that I should thought out ahead of tyme. On the CBR F4 you take off the side n center fairings, the tank, unbolt the radiator and lean it fwd, and I removed the airbox to access the coil packs n plugs. And they are deep recessed into the head. So you are limited with space to get the coil packs out, get you plug wrench in n get the plug out n back in. There is a reason mc mechanics make what they do
post #8 of 17 (permalink) Old 09-16-2007, 11:35 PM
ouch... I think plugs were $2.50 for the 250
post #9 of 17 (permalink) Old 09-16-2007, 11:38 PM Thread Starter
The reason its a 250 lol
post #10 of 17 (permalink) Old 09-16-2007, 11:45 PM
how many miles on the plugs? they can usually last awhile by bead blasting and regapping. unless the bike was running hot and burned the plug tips.
post #11 of 17 (permalink) Old 09-16-2007, 11:50 PM Thread Starter
not sure. bike had 37k on it when I bought in may. It now has almost 42k. They dont look bad and it was running great, maybe just a tad on the rich side at idle. Was a while I had it tore down might as well do it things
BTW BM whats the best plug wrench tool combo you've found to use?
post #12 of 17 (permalink) Old 09-16-2007, 11:55 PM
plug wrench combo? i use the one that came with the bike...
post #13 of 17 (permalink) Old 09-16-2007, 11:57 PM Thread Starter
ok, thats sorta what I am using plus a ratchet, but I think my tool kit is incomplete
post #14 of 17 (permalink) Old 09-17-2007, 12:19 AM
I'm pretty sure thats the best way to do it...
post #15 of 17 (permalink) Old 09-17-2007, 12:20 AM
...On the CBR F4 you take off the side n center fairings, the tank, unbolt the radiator and lean it fwd, and I removed the airbox to access the coil packs n plugs. And they are deep recessed into the head. So you are limited with space to get the coil packs out, get you plug wrench in n get the plug out n back in. There is a reason mc mechanics make what they do
On my old CBR, the gas tank hinges up at the seat, a strut rod holds it in place, and provides access to each plug. On my Suzuki, the plugs are in the wind stream. I could change them while sitting on the saddle.
post #16 of 17 (permalink) Old 09-17-2007, 12:25 AM
Wow that sucks. I just swing my tank up on its hinge, lock the hinge in place and they're right thurrrr on top of the engine.
post #17 of 17 (permalink) Old 09-17-2007, 12:27 AM Thread Starter
my 88 CBR was alot easier to get to than th F4. Nuttin I cant handle just didnt plan it out right out is all Also just figure out the tool kit I got went to a older model than mine and the plug tool if diff.
