Changing spark plugs - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 55 (permalink) Old 09-17-2007, 08:43 AM Thread Starter
Are changing spark plugs a pain in the ass on all sprt bikes? I changed mine this weekend. Cylinders 1 and 4 were fairly easy once I got the gas tank off. 2 and 3 are nearly impossible since the gap between the head and the bike frame are about the same as the length of the spark plug. Getting a spark plug socket down there is extremely difficult. Next time, I will save the headache and pay a dealer to do it.
post #2 of 55 (permalink) Old 09-17-2007, 09:24 AM
Saving headaches = wasting moneys.
post #3 of 55 (permalink) Old 09-17-2007, 09:29 AM Thread Starter
Maybe, but there has to be an easier way. I was almost at the point where I thought I would have to drop the engine to get the inside cylinder plugs out.
post #4 of 55 (permalink) Old 09-17-2007, 09:31 AM
If you got the money, sometimes it is better to say "f**k it" and let someone else do it. I wouldn't take it to a stealership though. I would find a good garage that only does that as their main business. Usually a lot cheaper too.
post #5 of 55 (permalink) Old 09-17-2007, 09:31 AM
does your spark plug grabber have a pivot on it? I use a socket wrench with a long extension, then a spark plug attachment that looks like the one on the right:
Maybe that would help
post #6 of 55 (permalink) Old 09-17-2007, 09:34 AM Thread Starter
That isnt long enough to fit down into the head and have the socket wrench reach it. I'd have to use a socket extenttion. The spark plug boot is about 5 inches long.
post #7 of 55 (permalink) Old 09-17-2007, 09:37 AM
Well I use that attached to a couple extenders attached to the socket wrench. Maybe the swivel would allow you a little bit of play upon removing it...
post #8 of 55 (permalink) Old 09-17-2007, 09:45 AM Thread Starter
The swivel wouldnt really help. the biggest problem though is getting the spark plug boot on and off. There just insnt enough space. I though I was going to break them.
post #9 of 55 (permalink) Old 09-17-2007, 10:01 AM
take it to the dealer, or a shop, but dont leave, watch how they do it. problem solved. nothin wrong with goin to some1 else to get somethin done, just make sure you watch and learn so u can do it next time.
dnyce is offline
post #10 of 55 (permalink) Old 09-17-2007, 10:56 AM
hint: remove the airbox
post #11 of 55 (permalink) Old 09-17-2007, 11:05 AM Thread Starter
That doesnt help at all, thats not even close to being in the way.
post #12 of 55 (permalink) Old 09-17-2007, 11:33 AM
it help helped on my cbr instead of trying to work the wrench thru the front.
And ya can see why ppl make the mooney they do working on bikes now??
post #13 of 55 (permalink) Old 09-17-2007, 11:48 AM
What brand socket are you using? Try Snap-on... the socket wall thickness is less thick and allows for more clearance. Use a piece of 1/4" rubber tubing to remove and install the plug- it just grips the tip on top of the plug... just use the socket to break the plugs loose and to tighten them down.
TOMMYTOM is offline
post #14 of 55 (permalink) Old 09-17-2007, 11:48 AM Thread Starter
Cant work on it from the front, the radiator is in the way. You have to get to it from the sides. Even if you had clean access all the way around, the engine is just way to close to the frame above it.
post #15 of 55 (permalink) Old 09-17-2007, 11:56 AM
I re-read your issue and edited my post- I thought your clearance issue was inside the spark plug access hole thru the head- but I see now you are talking about between the opening and the bottom of the frame.
But this really doesn't help if you cant even get the socket in there to break them loose- ??? Good question- I never had that problem with any of my bikes.
TOMMYTOM is offline
post #16 of 55 (permalink) Old 09-17-2007, 12:14 PM Thread Starter
The rubber tubing is a good suggestion, but the bigger probelm is getting the spark plug boot on and off.
post #17 of 55 (permalink) Old 09-17-2007, 12:26 PM
I had to loosen the radiator n drop it down n fwd, per the manual, doesnt really help with front access but gives more room from the side. but our bikes are diff I'm off to finish mine now Kirks's had my plugs in stock n I saved $4 over what Advanced tards charged me
post #18 of 55 (permalink) Old 09-17-2007, 01:42 PM Thread Starter
Ok after reading another forum, I got it figured out. The tool kit comes with a spark plug wrench. I didnt even think of looking in there for it. Also, there are some things I need to remove to get the spark plug coil out. It can be done, just need to have patience. Its a pain in the as but Im glad I only have to do it every 7500 miles.
post #19 of 55 (permalink) Old 09-17-2007, 01:56 PM
post #20 of 55 (permalink) Old 09-17-2007, 03:40 PM
This is a classic case of the fin manual I figured ya was using the plug wrench that came with the kit
Anyhow
got mine done she runs even better now.
