Help With My Cooling (OH AND I LOVE CAPS) - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 13 (permalink) Old 09-19-2007, 07:37 PM Thread Starter
I Have A Gsxr 1000 01 And Since I Have Changed My Sparkplugs And My Coolant My Bike Runs Hotter And The Fan Stop Working. I Changed From Ngk 9 To Ngk 8 Is It Possible That I Have A Higher Burning Spark Plug That Causes My Bike To Run Hotter? And My Fan Just Stopped Working, It Works Becuz I Jumpered It Out And It Turns When I Do That. What Could Be The Problem And Someone Said It Could Be My Fan Relay Where Is That Located?
ROODOG33 is offline
post #2 of 13 (permalink) Old 09-19-2007, 07:39 PM
ill come pick it up and fix it for ya no prob
Carolina is offline
post #3 of 13 (permalink) Old 09-19-2007, 07:40 PM
someone may be able to help you, moved to suzuki section
post #4 of 13 (permalink) Old 09-19-2007, 07:55 PM
in my experience-going one step hotter or colder shouldnt cause all those problems. as it is said, "check the last thing you did, make sure you did it right" could also just be a relay or thermostat prob too
dnyce is offline
post #5 of 13 (permalink) Old 09-19-2007, 09:19 PM
Shazam, new mod strikes again...
must say i'm impressed... couple days with "the power" and no noticable shenanigans.
post #6 of 13 (permalink) Old 09-19-2007, 09:31 PM
JoJoYZF's Avatar
Send a message via AIM to JoJoYZF Send a message via Yahoo to JoJoYZF
yet...
JoJoYZF is offline
post #7 of 13 (permalink) Old 09-20-2007, 01:20 AM
post #8 of 13 (permalink) Old 09-20-2007, 02:09 AM
Ok you said that you changed your coolant and spark plugs, I don't think that plugs would mess with your cooling system much especially just moving one temp range. So on to coolant, Did you make sure you got all the air out? Did you start the bike and let it get to operating temp so it would start circulating the coolant (the thermostat opens at 180*) and then did you have to ad anymore?
How hot it your coolant temp? (your fan switch turns the fan on at 221* and then shuts back off at 212*)
You can check your temp sensor if you have a multi meter or ohm meter:
At 68* your resistance should be ~ 2.45 K ohms
122 ~ .811 K ohms
176 ~ .318 K ohms
230 ~ .142 K ohms
Also check your cooling fan Fuse
Ok and to answer your question about where the relay is. Its under your seat in front of your battery carrier. it located on the right side of the fuel pump relay. to test disconnect the connector and use a multi meter to check for continuity between pin 1 and 2, there should be no continuity. now use jumper wires one connected to the positive terminal of your fully charged battery to pin 3 on the relay and the other jumper from your negative terminal on your battery to pin 4 on the relay, now check for continuity between pin 1 and 2, there should now be continuity.
Sorry for the long post but I have my Haynes right here and couldn't resist.
If you don't understand anything I have said then you should probably take your bike to a shop.
Joe4g63gsx is offline
post #9 of 13 (permalink) Old 09-20-2007, 02:09 AM
oh and like GasMan said turn your caps lock off!
post #10 of 13 (permalink) Old 09-20-2007, 08:28 AM
Shouldn't this go to tech?
post #11 of 13 (permalink) Old 09-20-2007, 07:15 PM
Good call.. and I added a somin special too!
post #12 of 13 (permalink) Old 09-20-2007, 07:41 PM
Nice work. Admins all!
post #13 of 13 (permalink) Old 09-20-2007, 09:53 PM
I wondered which of you boys did that. Nice touch....
neebelung is offline
