Acess an air filter on a 636 - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 09-20-2007, 10:36 PM Thread Starter
can any one help i cant seem to figure out how to acess the air filter on my bike i know its under the tank but how do ya get the tank losse i tried but cant seem to figue it out
'05 636 Rocket is offline
post #2 of 7 (permalink) Old 09-21-2007, 08:42 AM
I'm not sure how to translate "losse"; loose?
Anyway, getting the tank off requires removal of the side panels along the driver's seat, then the seat itself, then the big bolt/nut combo under the seat, then the bolt at the gauge end of the tank (metric allen IIRC, 7?), then the two side allen bolts that are right on the frame and are colored black. I suspect you didn't note those latter two and thus your problem. They're allen wrench bolts too, but the size escapes me.
The fuel line is a quick disconnect so you'll need some help probably to get it off if you want to be really careful. While you're working on the air filter you'll want to keep the tank in an upright position to minimize gas spillage. I use a 5 gallon bucket that orignially had asphalt tar and the fuel pump and fuel lines sit nicely in the bucket with the tank in its natural position; balances beautifully.
kanwisch is offline
post #3 of 7 (permalink) Old 09-21-2007, 09:12 AM
hmm I know on my bike side panels seat. then 2 bolts that holds the front of the tank. My gas tank is hinged on the back and i just use my handy Tank prop. to Kinda like the thingy you prop the hood up and my air filter is under my Gas tank. BUT thats on an SV don't know nada about Kawas.
papapoi is offline
post #4 of 7 (permalink) Old 09-21-2007, 09:50 AM
It is the same with the 636. You can leave the bolt/nut (under driver's seat) on and flip the tank up toward the back as you suggest if you can find a prop and you won't be in there long.
kanwisch is offline
post #5 of 7 (permalink) Old 09-21-2007, 09:47 PM Thread Starter
thanks guys helps alot cause i didn't happen to think bout the bolt under the seat again thanks
post #6 of 7 (permalink) Old 09-21-2007, 11:12 PM
Glad we could help.
papapoi is offline
post #7 of 7 (permalink) Old 09-22-2007, 02:36 PM
