cant get brake lights to come on? GSXR 600 2002 - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 8 (permalink) Old 09-21-2007, 12:22 AM Thread Starter
Just bought a 2002 GSXR 600 with a undertail kit with integrated tail lights/brake/ turn signals have had to hook these ****ers up like 10 times.
i have a constant tail light and turn signal but when i hook up the brake light wire to the unit it doesn't make the amber lights any brighter have checked the wire with DMM to see if the voltage changes and it does. both lights are a 12v system and have around 11.5-12v constant to keep tail lights on. when either rear or front brake is engaged it supplies another 12.v to the brake wire which in theory should make the lights brighter but it does not ...Wondering if their was a way to reduce power from the constant power wire to only around 6.5-7v to lessen the glow of the light until the brake was hit sending the full 12v to the lights...... anyone else run into this kind of problem looking for sum kind of solution!?!?!? otherwise i guess i might have to buy a new under tail kit or sum separate tail lights
02GSXXR is offline
post #2 of 8 (permalink) Old 09-21-2007, 01:26 AM
First off
Have you checked the bulb to make sure it has dual filiments?
post #3 of 8 (permalink) Old 09-21-2007, 01:30 AM
Question
r they LEDs or do they use reg. bulbs
'05 636 Rocket is offline
post #4 of 8 (permalink) Old 09-21-2007, 12:50 PM Thread Starter
Yes they are led's and are suppose to be used for this kind of lighting
02GSXXR is offline
post #5 of 8 (permalink) Old 09-21-2007, 01:04 PM
When I installed mine it had to be plug in to a certain plug. (one of the original bulb sockets). Wouldnt work at all plugged into the wrong one.
post #6 of 8 (permalink) Old 09-21-2007, 01:30 PM Thread Starter
removed the bulbs using just straight wiring to the wires i already have stopped by suzuki and they even said to eliminate those plugs
02GSXXR is offline
post #7 of 8 (permalink) Old 09-21-2007, 11:58 PM
I used the plugs when I did the LED tail light conversion on my 9R... no problems.
post #8 of 8 (permalink) Old 09-22-2007, 07:20 PM Thread Starter
Well finally fixed them after couple hours of bull****. the kid before had wired them up like **** so i started over and ended u having to cut into the plastic lights to get to the different metal ends for each purpose and soder new wires comin out of the lights... but they now work great with no problems
02GSXXR is offline
