Green Liquid Please Help - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 16 (permalink) Old 09-26-2007, 10:55 PM Thread Starter
today i was driving to work...when i got to work some lady pulled out of a parking spot toooo fast and i had to hit the brakes and i dropped the bike going about 1 mph on the right side.....then green and clear stuff came out of the bottom of my bike....for like 10-20 sec then it stopped....what could this be....rode the bike to a friends house with a garage tonite so i can look at it tomorrow and it didnt overheat or act up at all....PLEASE HELP
tschmidt098 is offline
post #2 of 16 (permalink) Old 09-26-2007, 10:58 PM
prolly from the overflow tank.
post #3 of 16 (permalink) Old 09-26-2007, 11:05 PM
JoJoYZF's Avatar
Send a message via AIM to JoJoYZF Send a message via Yahoo to JoJoYZF
Im with playful on this one. Mine spilled some gas when I dropped it last week from the overflow.
JoJoYZF is offline
post #4 of 16 (permalink) Old 09-26-2007, 11:26 PM
yeah it's probably coolant from the overflow tank... smell it... if it smells sweet it's coolant... it's also extremely slick feeling... if it's coolant clean it up quick you don't want that **** on your tires!
post #5 of 16 (permalink) Old 09-26-2007, 11:33 PM
I totally thought this was another poop thread...
post #6 of 16 (permalink) Old 09-26-2007, 11:34 PM
if it was he would have some serious issues
post #7 of 16 (permalink) Old 09-27-2007, 12:01 AM
green... is coolant as described above.
While most gasoline is green, I doubt you can see that color of the gas when its on the ground. Besides most people know what gas smells like.
post #8 of 16 (permalink) Old 09-27-2007, 12:13 AM
JoJoYZF's Avatar
I was looking more at the part about the clear stuff he mentioned. I forogt to even say anything about the green being coolant like I meant too.
JoJoYZF is offline
post #9 of 16 (permalink) Old 09-27-2007, 12:30 AM
Maybe it was both!
post #10 of 16 (permalink) Old 09-27-2007, 11:15 AM Thread Starter
it did smell like gas too but i did just leave the gas station i thought maybe i just spilled a little.....thanks guys do i need to go through all the trouble of taking the fairings off to check the coolant and add more or will i be ok
post #11 of 16 (permalink) Old 09-27-2007, 11:22 AM
depends on how much you've leaked... TAKE THEM OFF! you don't wanna over heat down the road because you were to lazy to check the coolant now...
besides may help you find out why it's leak'n... you may have (unlikely but not unheard of) cracked the over flow tank or a hose. trust me... on the side of the road isn't where you wanna be second guess'n yourself.
Take them off... and not only check the level... but inspect the hoses/tank and what ever else you think might have caused it...
either way....
post #12 of 16 (permalink) Old 09-27-2007, 11:44 AM Thread Starter
how hard and long does it usually take to check the coolant
post #13 of 16 (permalink) Old 09-27-2007, 11:51 AM
depends on the bike... mine.. I can just pop off a side panel and take a look... no more than 15 mins and 5 bolts start to finish. but if I'm inspecting I'd take as long as it takes for me to feel comfortable I found the problem.
post #14 of 16 (permalink) Old 09-27-2007, 12:02 PM
Gas is green??? Looks tan to me except the military fuel, that's dyed green
post #15 of 16 (permalink) Old 09-27-2007, 12:20 PM Thread Starter
it was hardly any of the coolant came out it was mostly the stuff that you guys think is gas
post #16 of 16 (permalink) Old 09-27-2007, 05:36 PM
Gas is nearly always green. Sometimes darker, sometimes lighter...
I will get a pic when I go back to work of my sampler system running.
Gasoline is a nice light green
Ultra Low Sulfer Diesel is either a similar color or like tennis ball green
Jet & kero are either straw but mostly WW (Water White) aka Clear
High Sulfer or Off-road diesel is purposely died dark red
Propane is clear/WW but only during the time its weathering (turning from liqued to a gas/vapor state)
