Hay Guyyz, What Happenz When... - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 21 (permalink) Old 09-28-2007, 10:03 AM Thread Starter
You clean your o-ring chain with gasoline?
kbubp is offline
post #2 of 21 (permalink) Old 09-28-2007, 10:06 AM
You dry out the rubber rings.
post #3 of 21 (permalink) Old 09-28-2007, 10:08 AM Thread Starter
I thought so. Is this irreparable, or can you just put some white lithium on there and be done with it?
kbubp is offline
post #4 of 21 (permalink) Old 09-28-2007, 10:11 AM
i use this stuff on my chain.
papapoi is offline
post #5 of 21 (permalink) Old 09-28-2007, 10:12 AM
I doubt that would work. The rings wont soften back up. Once the rings dry out and crack, you need a new chain.
post #6 of 21 (permalink) Old 09-28-2007, 10:12 AM Thread Starter
Interesting. I usually just clean it with Kerosene and lube it with Honda Lube, but the Honda Lube is all sticky and annoying.
Silicone on the other hand... nice.
kbubp is offline
post #7 of 21 (permalink) Old 09-28-2007, 10:13 AM Thread Starter
I have one, I was just curious.
kbubp is offline
post #8 of 21 (permalink) Old 09-28-2007, 10:14 AM
good stuff doesn't pick up alot of dirt and go on SO much cleaner. plus it has teflon in it.
papapoi is offline
post #9 of 21 (permalink) Old 09-28-2007, 05:39 PM
Clean it with kero and lube... but understand the only reason to lube is to keep surface rust off the outside rivits... the chain itself don't need the lube... that's why you have o/x-rings
post #10 of 21 (permalink) Old 09-29-2007, 03:23 PM
Well... I use PB Blaster and Chain Wax. 5,000 miles, and I turned my adjusters less than 1/2 turn today. Enough to bring the slack from just outside the 40mm spec to the low side at 30mm. I know the Blaster is lighter than Kero, but I haven't had any ill effects.
Just got my T-Rex stands! Love them- they make waxing the chain and adjusting it a ton easier. Have to modify my cleaning method to work with the stands though.
Got Gear?
post #11 of 21 (permalink) Old 09-29-2007, 04:30 PM
I use a motorex street clean and lube kit. You can get it at kneedraggers for like 20 bucks. It comes with a can of chain cleaner, a can of chain lube, a mini can of chain lube to keep in yer jacket, and a cleaning cloth
post #12 of 21 (permalink) Old 09-29-2007, 05:37 PM
a can in ya jacket? how bout under the seat wallet n cell would hurt bad enough if ya went down, but a can?? can you say OUCH
post #13 of 21 (permalink) Old 09-29-2007, 11:27 PM
the man knows his chains...
post #14 of 21 (permalink) Old 10-19-2007, 04:09 PM
didn't wanna start a new thread so I'll just post it here... I just cleaned my chain with superclean (what I was told to use by the shop that put the chain and sprocket on) and when I lubed it with PJ1 blue it binds up bad... I've never done this before so I'm not sure if I'm do'n something wrong... I figured it was pretty simple... I decreased it scrubbed with the chain brush and then sprayed it off with a hose.... (like the instructions said...) then started spray'n the PJ1 Blue lube. I've used almost the entire can and it's bind'n up... bad... I feel like an idiot...
post #15 of 21 (permalink) Old 10-19-2007, 04:32 PM
i use this is that bad???
02GSXXR is offline
post #16 of 21 (permalink) Old 10-19-2007, 04:43 PM
.. now seriously
post #17 of 21 (permalink) Old 10-19-2007, 06:41 PM
Originally Posted by ebbs15 View Post
.. now seriously
i fig someone would find that humorous
02GSXXR is offline
post #18 of 21 (permalink) Old 10-20-2007, 11:11 AM
Talk about chain binding!
Got Gear?
post #19 of 21 (permalink) Old 10-20-2007, 11:25 AM
get a friend to film you after you light it on fire... have him screaming "oh my god its ghost rider!".
post #20 of 21 (permalink) Old 10-23-2007, 04:54 PM
Is it all better now Ebbs??
Have you taken it for a ride since??
