change chain? how often - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 24 (permalink) Old 10-02-2007, 11:59 PM Thread Starter
So I took my bike to the shop for the 12k service and he said I also need new chain and sprockets. is thins normal mileage to be changing the chain out?? thanks.
NorCal916 is offline
post #2 of 24 (permalink) Old 10-03-2007, 12:05 AM
yep, 12k is normal for the factory chain, may not have to change the sprockets but you should if youre doin the chain
MidwesterneRR is offline
post #3 of 24 (permalink) Old 10-03-2007, 12:13 AM Thread Starter
K thanks just dont want to get screwed by a shop.
post #4 of 24 (permalink) Old 10-03-2007, 01:43 AM
If you take it to the shop at all, you can't avoid that.
post #5 of 24 (permalink) Old 10-03-2007, 01:56 AM Thread Starter
yea I learned that, but Ive also learned that having your "mechanic" friend work on it isnt always the best idea either..
post #6 of 24 (permalink) Old 10-03-2007, 02:22 AM
buy a manual n learn to do it yourself. It will bring you n your bike closer
post #7 of 24 (permalink) Old 10-03-2007, 03:43 AM Thread Starter
good idea, ive just never trusted myself to do the work..
post #8 of 24 (permalink) Old 10-03-2007, 06:28 AM
well, its either that or take a big jar of lube when you go to the dealer.
post #9 of 24 (permalink) Old 10-03-2007, 09:40 AM
Getting anything from a dealer sucks.
Got Gear?
post #10 of 24 (permalink) Old 10-03-2007, 09:09 PM
DING DING DING
YOU ARE WRONG WRONG WRONG!!!!
You must always replace all 3 parts at the same time. if not you will prematurely wear the new parts.
Trust me on this... if you don't ask around... my is worth listening to.
post #11 of 24 (permalink) Old 10-03-2007, 09:12 PM
DING DING DING
post #12 of 24 (permalink) Old 10-03-2007, 09:16 PM
No. Unless you used battery acid to lube the chain, it should last thousands of miles more. Is the chain rusty? Has it reached the end of adjustment? Was it adjusted too tight? Is it noisy? Will the wheel spin freely? Are there kinks in the chain? Did he say why they must be replaced?
post #13 of 24 (permalink) Old 10-03-2007, 10:02 PM
download a manual n learn to do it yourself. It will bring you n your bike closer
Fixed it for ya
post #14 of 24 (permalink) Old 10-03-2007, 10:03 PM
Originally Posted by fpzx10 View Post
Fixed it for ya
ty yea I coulda used get huh
post #15 of 24 (permalink) Old 10-05-2007, 01:13 AM
DING DING DING
I meant he doesnt have to as in his tires arent going to fall off if he doesnt, however i completely agree, i would never do one without the other
post #16 of 24 (permalink) Old 10-05-2007, 08:33 AM
Yeah sure... but most of the time you'll find that when the chain is worn out most of the time so is the rear sprocket.
post #17 of 24 (permalink) Old 10-05-2007, 11:03 AM
i should get a pic of a vortex rear i took off of a friends bike(he left it through 2 chains) i cant figure out how it moved the tire, it was almost smooth on the outside.
post #18 of 24 (permalink) Old 10-05-2007, 11:31 AM
GM has some good Vortex sprocket pics...
post #19 of 24 (permalink) Old 10-06-2007, 02:27 AM
YEP! Can we say JUNK?
post #20 of 24 (permalink) Old 11-03-2007, 06:23 AM Thread Starter
they said chain was past the wear mark, but i ended up going down 2 teeth in the rear for a lil more torque anyway.
