motor rebuild - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 6 (permalink) Old 10-10-2007, 07:46 AM Thread Starter
motor rebuild
im tryin to rebuild my 01 rm 125...how do i split the case..i have no spare money to take it into a shop..i have all parts to fix it..so if someone can help me much appreciated
SMFB636 is offline
post #2 of 6 (permalink) Old 10-10-2007, 09:39 AM
not exactly sure on that model, but shoould be some place to pry apart, just be carefull not to gouge any metal. i would suggest investing in a service manual it should tell ya anything and everything ya need to know.
bowb4me is offline
post #3 of 6 (permalink) Old 10-10-2007, 10:22 AM
Why do you need to split the case? Are you installing a new crank or piston rod? If all you are changinfg is the piston, rings and bearing, you dont need to split the case.
post #4 of 6 (permalink) Old 10-11-2007, 05:00 PM Thread Starter
i need to split the case to replace the crank...i have all the parts and gaskets
SMFB636 is offline
post #5 of 6 (permalink) Old 10-11-2007, 08:16 PM
service manual bro... you will fux0r it up without one.
post #6 of 6 (permalink) Old 10-12-2007, 07:14 AM
I suggest buying this book.
http://www.eric-gorr.com/mxandoffroad.html
