01 Hayabusa - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 9 (permalink) Old 12-11-2004, 04:17 PM Thread Starter
01 Hayabusa
Hello Guys
I need help so thought i would ask here. I'm building a trike and have a 01 Hayabusa complete front end i want to use. Can anyone tell me if the Hayabusa frame has a steel neck inside the casting of the frame or is it just part of the casting
I need to have a steel neck made but don't know how long it should be I have a set of bearings to send to the guys thats going to make it . But with the seals and bearing i want to be sure the neck he makes will work. I will be welding it to a homemade trike frame. Thanks for any help you may offer .God Bless Buddy in Jax Fl
flash369 is offline
post #2 of 9 (permalink) Old 12-11-2004, 04:20 PM
There's nothing steel in a Hayabusa frame. The steering head is just cast alumininum. The steering stem is part of the triple tree (it's pressed into the bottom triple clamp). There's no sleeve where the stem goes in. There's just top and bottom bearings pressed into the steering head.
And welcome to TWF.
GSXR1000DJ is offline
post #3 of 9 (permalink) Old 12-11-2004, 05:16 PM
I wonder if Buasbabe would know?
post #4 of 9 (permalink) Old 12-11-2004, 05:39 PM
we know Larryg would know..he'll make his rounds on TWF tonite like usual.
Need4Speed is offline
post #5 of 9 (permalink) Old 12-11-2004, 05:44 PM
Thats cool...you guys can skip over my answer. Its right but I see how it is.
post #6 of 9 (permalink) Old 12-11-2004, 09:36 PM
busa- Alum
i didnt know a busa frame was all Alum... So why the hell is the bike so heavy other then the 1300cc STEEL block????
ScottSellersUNR is offline
post #7 of 9 (permalink) Old 12-11-2004, 10:03 PM
becuz we want an expert opinion..
post #8 of 9 (permalink) Old 12-12-2004, 12:43 PM
Just like DJ said, the frame is aluminum. The only steel in the neck is the bearing races.
post #9 of 9 (permalink) Old 12-13-2004, 12:36 PM
And look at larryg's reply. Looks like I was right.
