I think my swingarm is bent... - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 20 (permalink) Old 10-13-2007, 02:33 PM Thread Starter
But there are no local shops around to test it for me... how can i be sure? Level and measure for squareness?
kbubp is offline
post #2 of 20 (permalink) Old 10-13-2007, 02:58 PM
Call Bryan
post #3 of 20 (permalink) Old 10-13-2007, 03:04 PM Thread Starter
Then I won't learn anything.
I can't believe you didn't do your own brakes.
kbubp is offline
post #4 of 20 (permalink) Old 10-13-2007, 03:09 PM
I am a bad mechanic, I want the brakes to work.
post #5 of 20 (permalink) Old 10-13-2007, 03:10 PM Thread Starter
Where do they get these ads? It's hilarious.
But, you know, I would have helped you... I have a lot of experience putting bikes together
kbubp is offline
post #6 of 20 (permalink) Old 10-13-2007, 03:11 PM
Bryan is cheap and does good work.
post #7 of 20 (permalink) Old 10-13-2007, 03:18 PM Thread Starter
Yeah $40 per wheel to mount a tire?! (If the wheel is off the bike, more if it is still on)
I'm buying a no-mar.
kbubp is offline
post #8 of 20 (permalink) Old 10-13-2007, 04:04 PM
Ah, he is $20 per wheel if the wheel is off, $40 total. Same at In The Wind if you don't buy it there and they scratch the sh*t out of your wheel. You don't listen very well.
post #9 of 20 (permalink) Old 10-13-2007, 04:28 PM
Don't crash... then your swingarm will stay straight.
Which way do you think it's bent? A suppose a level could work, depending on where/how it's bent.
post #10 of 20 (permalink) Old 10-13-2007, 05:08 PM
d00d if you can do your own undertail n pipe you can do brakes actually doing brakes is easier.
post #11 of 20 (permalink) Old 10-13-2007, 05:25 PM
I rather others do the work, I can easily afford it and I don't care to learn. Plus, the guy I am using now knows his sh*t.
post #12 of 20 (permalink) Old 10-13-2007, 06:25 PM
Look up your local gmd computrack or traxxion dynamics. Trailer it over there.
Or try to find a spare swingarm on ebay for cheap... replace the bearings when you install it.
post #13 of 20 (permalink) Old 10-13-2007, 08:31 PM
remove the swingarm and lay it flat on the ground. start measuring. i've done that before. i have a matt with gridmarks to check alignment.
post #14 of 20 (permalink) Old 10-13-2007, 09:12 PM
nothing wrong with that I guess
I do all my wrench turning.
post #15 of 20 (permalink) Old 10-14-2007, 12:36 PM
You're actually better off to lay it on a piece of glass... like a glass table or window. Something you know is truely flat. Or a something that you can take a level to, to ensure its completely flat.
Also, stick the axle thru the swingarm and put a level on that once the swingarm itself is leveled. See if the axle holes are true. Also measurements from center of axle to the pivit bolt.
post #16 of 20 (permalink) Old 10-14-2007, 03:06 PM Thread Starter
Measured. It's straight. We're good to go.
New thread with pics soon.
kbubp is offline
post #17 of 20 (permalink) Old 10-14-2007, 07:25 PM
Pics or ban!!
post #18 of 20 (permalink) Old 10-14-2007, 08:33 PM Thread Starter
Pics or ban!!
I made a new thrad y0.
PLZ DONT BAN ME!!!
kbubp is offline
post #19 of 20 (permalink) Old 10-15-2007, 01:25 AM
I saw and I wasn't going to...
post #20 of 20 (permalink) Old 10-15-2007, 01:55 PM
PLZ DONT BAN ME AGAIN!!!
Fixed it for ya
