tire change vid..... - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 16 (permalink) Old 10-19-2007, 11:01 PM Thread Starter
hope it's not a repost.
found this interesting, wish it had some explanations with it.
post #2 of 16 (permalink) Old 10-20-2007, 02:10 AM
There are many others as well...
post #3 of 16 (permalink) Old 10-20-2007, 05:14 AM
if your showing how to remove check out the balancing... Scudman also sells the tool for $50 so you can DIY
02GSXXR is offline
post #4 of 16 (permalink) Old 10-20-2007, 01:25 PM
i just order this today (motorcycle tire changer)...
it comes in two parts:
http://www.harborfreight.com/cpi/cta...emnumber=34542
http://www.harborfreight.com/cpi/cta...emnumber=42927
now i'm gona make a tire balancer...
post #5 of 16 (permalink) Old 10-20-2007, 01:33 PM
I hope you have better luck with it than I did...
https://www.twowheelforum.com/showthr...anging+machine
If you cancel your order and can wait a couple weeks, I'll bring mine down there on my way to Orlando and sell it to you for $75.
post #6 of 16 (permalink) Old 10-20-2007, 02:01 PM
oh...
tire changers are finicky. i've used the pnumatic ones when i worked at pepboys (autosource at morse road before they closed down).
it didn't cost much. but hey, i'll make a vid on how to properly use it.
post #7 of 16 (permalink) Old 10-20-2007, 02:03 PM
oh...
You interested in mine... Only used once... and cursed at often...
post #8 of 16 (permalink) Old 10-20-2007, 02:19 PM
yea man sucks how much did you pay for that thing casue if its like 200+ then go make it def.
02GSXXR is offline
post #9 of 16 (permalink) Old 10-20-2007, 02:31 PM
PORTABLE TIRE CHANGER 34542-8VGA 49.99
MOTORCYCLE TIRE CHANGER ATTACHMENT 42927-6VGA 49.99
Sub Total: 99.98
post #10 of 16 (permalink) Old 10-20-2007, 02:42 PM
is it the same brand? the principle is the same with all tire changers, break the bead and pry off the tire.
i've done so many that cheap machines don't bother me.
i prefer using this tire iron than the one it comes with...
there are different methods to prevent scatches. make sure you use plenty of soapy water. i haven't scratched a rim yet.
remember the first time you used a hammer for the first time. it's very similar, once you use it enough times, it becomes second nature.
i've bent many a nails the first time i used a hammer.
post #11 of 16 (permalink) Old 10-20-2007, 02:44 PM
It's that exact same setup... The tire iron that comes with it is also used as a bead breaker bar so it's like 4ft long and weighs 15lbs... Probably had a lot to do with my difficulties.
post #12 of 16 (permalink) Old 10-20-2007, 11:25 PM
Yeah no... sometimes there are things better to have done...
post #13 of 16 (permalink) Old 10-21-2007, 12:29 AM
PiZdETS's Avatar
True story.
Like pumping my septic tank, colonoscopies and getting my pubes waxed, I find it worth the money to leave to the professionals.
Patience is something you admire in the driver behind you and scorn in the one ahead. ~Mac McCleary
PiZdETS is offline
post #14 of 16 (permalink) Old 10-21-2007, 12:30 AM
Originally Posted by PiZdETS View Post
True story.
post #15 of 16 (permalink) Old 10-21-2007, 12:50 AM
PiZdETS's Avatar
J/k dude. I have them permed.
PiZdETS is offline
post #16 of 16 (permalink) Old 10-21-2007, 12:52 AM
