battery, missing something..... - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 17 (permalink) Old 11-05-2007, 02:48 PM Thread Starter
may sound stupid but,
this morning, since i was gonna be doing some errands,
decided to take the battery out of the bike to get it checked
and/or charged @ the local AutoZone. (haven't ridden since accident)
unscrewed the screws that hold the terminals to the posts then took it
out, no prob.
now i get back to put the battery back in, and the screws have nothing
to thread thru onto the posts.
don't remember hearing or seeing any nuts falling out of the posts.
anyone know what i'm missing or should be looking for?
tia.
post #2 of 17 (permalink) Old 11-05-2007, 02:51 PM
2 lil square nuts that slide into the post.
post #3 of 17 (permalink) Old 11-05-2007, 02:51 PM
usually there's a small flat square washer inside the terminal that it threads into. may have fell out.
bowb4me is offline
post #4 of 17 (permalink) Old 11-05-2007, 03:02 PM Thread Starter
great,
found one of them in the car.
the other's prob. gone.
gonna have to fab something up to replace the missing one.
thanks guys.
post #5 of 17 (permalink) Old 11-05-2007, 03:14 PM
hold one cable on the terminal and short it to the other it will weld the cable to the terminal.
bowb4me is offline
post #6 of 17 (permalink) Old 11-05-2007, 05:15 PM
Just go to ace hardware or home depot and get another nut.
firstcherokeekid is offline
post #7 of 17 (permalink) Old 11-05-2007, 05:34 PM Thread Starter
took care of the nut.
But,
while trying to clean her all up and putting everything back together
stripped one bolt that holds the tank in the rear and snapped another
that holds the tank in the front.
and the broken piece is still in the hole.
not having a good day.
looks like these will be over the winter projects added on to the list.
post #8 of 17 (permalink) Old 11-05-2007, 06:50 PM
Sucks about the tank.
You got the battery taken care of? If not I might have a nut I'll mail you if you need it.
post #9 of 17 (permalink) Old 11-05-2007, 07:01 PM
easeouts are your friend. check your local walmart, hardware store, etc. That and a drill and they shouldnt be to bad to get out. As long as you didnt cross thread them then you will need a tap to clean the threads up.
post #10 of 17 (permalink) Old 11-05-2007, 07:20 PM Thread Starter
yeah, took care of.
really appreciate the offer.
post #11 of 17 (permalink) Old 11-05-2007, 07:23 PM
Originally Posted by jalaan1 View Post
yeah, took care of.
You didn't want Marko to mail you his nuts???
post #12 of 17 (permalink) Old 11-05-2007, 07:30 PM Thread Starter
post #13 of 17 (permalink) Old 11-05-2007, 07:40 PM
1 nut.
post #14 of 17 (permalink) Old 11-06-2007, 06:26 PM
1 nut.
left or right?
post #15 of 17 (permalink) Old 11-06-2007, 09:59 PM
left or right?
Does it matter?
post #16 of 17 (permalink) Old 11-06-2007, 10:29 PM
March 2008 BOTM Winner!
pickle.of.doom's Avatar
The one that hangs lower
Jalaan, I was going to say "Look at a battery" at the shop and just happen to grab the square nut, but sounds like you got it.
FOr the bolt, EZ-out like PG said, or just get a set of left handed drill bits and use the small one on that bolt, it should be pretty loose in there since you just had it out. For the stripped one, run a tap of the same size thorough and you might be able to clean the threads, or run a tap one size bigger and buy a bolt that fits the new bigger hole, and drill out what it holds down if you need to as well.
pickle.of.doom is offline
post #17 of 17 (permalink) Old 11-07-2007, 08:16 AM Thread Starter
thanks for the info guys,
oh, and leave marko's nuts alone.
