97 GSXR 600 electrical issues - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 8 (permalink) Old 11-08-2007, 09:23 PM Thread Starter
My rectifier went bad about 2 months ago, I replaced it with a used one. prior to that and still going on now my headlight dims a little bit with acceleration or whenever I press my brakes. If the symptoms that I am observing is like a car my altenator is going bad... meaning my stator is going bad? Just need some confirmation. Can I test my stator, the same way you can test an altenator by removing battery cable while the engine is running? Any suggestions will be greatfull...
atalien25 is offline
post #2 of 8 (permalink) Old 11-08-2007, 10:15 PM
i don't think that will work with a bike. but you should be able to test it with a digital volt meter. i would recommend obtaining a service manaul, it should give you direction on testing it. you can test it for shorts, grounds, and be able to check the voltage(ac) output of the stator.
good luck.
bowb4me is offline
post #3 of 8 (permalink) Old 11-08-2007, 10:16 PM
i would also check your grounds. they can wreck havoc.
bowb4me is offline
post #4 of 8 (permalink) Old 11-09-2007, 12:14 AM
I agree. Get a digital voltmeter and manual. It could be the wires, connections, rectifier, regulator, stator, battery, or the moon may be in the wrong phase. Using a $20 voltmeter and directions in the repair manual, you can easily find out exactly what the problem is without wasting tons of money and time.
post #5 of 8 (permalink) Old 11-10-2007, 01:06 PM
Here's some info I passed on before... search button is your friend.
And here
post #6 of 8 (permalink) Old 11-12-2007, 07:39 PM
I agree, digital volt/ohm meter is your friend. much help in such a scenario.
post #7 of 8 (permalink) Old 11-15-2007, 02:56 PM
2wheeltech's Avatar
check all your grounds and i agree get your self a manuil and a volt meter
2wheeltech is offline
post #8 of 8 (permalink) Old 11-15-2007, 03:35 PM
2wheeltech's Avatar
i agree too volt meter, it sounds like i would lean to a bad ground
