My bars aren't straight when I'm going straight Help! - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 4 (permalink) Old 11-10-2007, 01:02 PM Thread Starter
I laid her down into a curb on the left side and went highside over. just put the damn thing back together but it almost seems like my forks are bent or my bars shifted or something. not sure how too fix it.any help would be great
TR!GGER is offline
post #2 of 4 (permalink) Old 11-10-2007, 04:29 PM
Welcome!
Get your front end up with a steering head jack. Like below
Then try to loosen the tripples and the axle... adjust it... spin the wheel and make sure its not binding. Should be able to re-tighten everything and get it back aligned...
That is if, there is nothing damaged.
post #3 of 4 (permalink) Old 11-10-2007, 04:31 PM
Here's what I do. stand directly over the bike, so you're staring directly down the forks, look at each one. they MAY be slightly bent, somewhere. its possible that they just got moved in the triple clamps a little, which would cause your problem too.
post #4 of 4 (permalink) Old 11-12-2007, 01:28 PM
It may be as simple as just that your clip-ons aren't adjusted to be straight.
