getting closer with the '73 H1 - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 102 (permalink) Old 11-18-2007, 06:23 PM Thread Starter
I've been working on my '73 Kawasaki H1D 500. One problem with two strokes that have sat too long is that the crank seals dry out with can dry out and cause catastrophic failure.
I found a "donor" motor that I've been getting ready to start. I just ( today ) got a really good deal on a fresh crank for the original motor.
So I "buttoned" everything up to start a rebuild of the original motor. You can see the original motor sitting next to the back tire. Here's what it looks like so far ( with "survivor" tank/paint/tail )
Here's what it looked like originally ( not my bike )
After this motor is done, I'll start on my '74 H1 500
Jeff
edit
Here's what it looked like after 20 years of storage. I had it in a friend's barn for a while. I traded a couple weekends of roof repair for dry storage. He moved my bikes to a leaky section of the barn. All three triples had rear drums corroded fast.
Last edited by '73 H1 Triple; 11-18-2007 at 07:48 PM. Reason: added a "before" pic
'73 H1 Triple is offline
post #2 of 102 (permalink) Old 11-18-2007, 06:49 PM
I like it. looks really good so far, all you need really is to get it running, then worry more about the looks.
btw, would you mind telling me what that rear tire is? I have one just like it on the CB550 I'm getting, and I want to get a few more of them.
post #3 of 102 (permalink) Old 11-18-2007, 07:09 PM Thread Starter
Dunlop Gold. I'm pretty sure there still making them as they are very popular for the restoration crowd.
Yes, I'll getting it running perfect before I dump money into paint.
post #4 of 102 (permalink) Old 11-18-2007, 07:22 PM
I love it. I had two triples, both Suzuki. In the early 70's my friend George had a maroon-colored H1 and took me for a ride. Lasted about two minutes. The front tire was in the air more than it was on the ground. And speaking of tires, I use Metzeler's Lasertec's on my GS1000. Skinny bias/ply with tubes, but on tight roads I can hang with the sport bikes.
post #5 of 102 (permalink) Old 11-18-2007, 07:49 PM Thread Starter
Added a "before" pic. I did clean the chrome the best I could for the pic
post #6 of 102 (permalink) Old 11-18-2007, 07:51 PM
mtp
looks great
mtp is offline
post #7 of 102 (permalink) Old 11-18-2007, 07:55 PM Thread Starter
Originally Posted by mtp View Post
looks great
Thanks Mike. Kind of tough to get parts from the dealer so Ebay and a couple of guys from the triple forum keep it going.
post #8 of 102 (permalink) Old 11-18-2007, 09:09 PM
'73 I suggest you sand and polish all that old chrome... then send it to Browns Plating for re-chroming... they will be getting about $1500 worth of chroming from me this winter!!! YUM... my favorite color "shiny"!!!
post #9 of 102 (permalink) Old 11-18-2007, 09:17 PM Thread Starter
There is chromer on Frankfurt Ave in Phila that does excellent work. I've been lucky enough to get nice pieces off ebay and from Jess Freeby for this one.
I've been putting "second best" on the '73 and saving the better pieces for the '74 H1.
If I can find a '73 H2 front fender ( for a decent price), those are polished stainless steel and can be polished with a buffer
post #10 of 102 (permalink) Old 11-18-2007, 09:24 PM
That tire I think has been around since 1975. my CB has a set on it that are the originals. yes I'm positive they're original too. bike only has 75xx miles, or somewhere around there.
post #11 of 102 (permalink) Old 11-18-2007, 09:36 PM Thread Starter
King Bob,
Try these place for parts for your CB http://www.partsnmore.com/
I've had very good luck with them. Minimum order is $35 and shipping is $3 flat rate
Jeff
post #12 of 102 (permalink) Old 11-20-2007, 11:38 AM
That is bad ass good work make a video once its running....
post #13 of 102 (permalink) Old 11-20-2007, 07:13 PM
King Bob,
Jeff
yo! thanks for the link.
post #14 of 102 (permalink) Old 11-20-2007, 08:16 PM Thread Starter
Here's a couple more
http://www.hvccycle.com/hvcpartscatalog.htm
http://www.oemcycle.com/
post #15 of 102 (permalink) Old 11-20-2007, 08:19 PM
Looking good Jeff!
Bfly71 is offline
post #16 of 102 (permalink) Old 11-20-2007, 08:32 PM Thread Starter
Originally Posted by Bfly71 View Post
Looking good Jeff!
Thanks Shannon
If all goes well, I should have two "smokers" ready by spring.
Here's what the '74 looked like new ( it's the same colors but this one isn't mine )
post #17 of 102 (permalink) Old 11-20-2007, 08:34 PM
Very nice! Maybe we can ride together some time.
Bfly71 is offline
post #18 of 102 (permalink) Old 11-20-2007, 08:42 PM Thread Starter
That would be cool
post #19 of 102 (permalink) Old 11-25-2007, 09:22 PM
Well keep us updated on this.
post #20 of 102 (permalink) Old 11-26-2007, 06:39 PM Thread Starter
Here's what I did yesterday.
I'm pulling apart the original engine to check out the trans, clutch and to drop in another crank with fresh seals.
Started with popping off the heads and pulling the cylinders.
You can see the 1.5 sq piece of wood for the in the exhaust port and the 2 lb hand sledge to "help". I also used KROIL to help break things free. The left and center cylinders ( as on the bike )broke free with a couple easy taps. The right cylinder was a little stuck towards the front of the engine. Tapping with the long wood and prying with the 2x4 in the intake manifold broke it free after about 10-15 minutes. I would get it up and smack it back down with the 2x4 on the top of the cylinder. Then back to the long board.
Pistons and the bores look pretty good.
I removed the spring clips and was able to lightly tap out the wrist pins while supporting the piston in my hand.
Jeff
