[Paging techies] Ignition coil for 99 SV650 - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 14 (permalink) Old 12-16-2004, 07:20 PM Thread Starter
I need to tap into it for a new accessory but I'm not sure where to FIND it. Can anyone assist?
post #2 of 14 (permalink) Old 12-16-2004, 09:58 PM
Follow the spark plug wire.
post #3 of 14 (permalink) Old 12-27-2004, 04:45 PM Thread Starter
Okay, I found an ignition coil for each cylinder. THere is an orange and a white wire coming out of it.
If I were say, installing a Veypor and it needed to be wired into the coil for RPM readings... which wire do I tap? Orange or white?
post #4 of 14 (permalink) Old 12-27-2004, 05:18 PM
I would say orange.
GSXR1000DJ is offline
post #5 of 14 (permalink) Old 12-27-2004, 05:41 PM Thread Starter
Originally Posted by GSXR750DJ
I would say orange.
Any reason why or is it just a guess?
post #6 of 14 (permalink) Old 12-27-2004, 05:43 PM
I would think that it would be orange more so than white.. white and black are usually for power and ground, so I would think given the choice orange would be a better, more educated guess.
post #7 of 14 (permalink) Old 12-27-2004, 06:45 PM
I would get a manual or wiring diagram. My CBR reads the tach off the spark unit. My old Suzuki uses a cable off the cam. When I put a tach in my old Jeep, I tapped off the coil. When I changed to an HEI (did away with external coil), it read off the distributor. If you use the wrong wire, it may fry the delicate ignition module, or something more expensive. That can cost more than several service manuals.
post #8 of 14 (permalink) Old 12-28-2004, 11:20 AM Thread Starter
It reads 30 RPM, so I'm assuming the white wire (I chose) is the wrong one.
larryg, any input?
post #9 of 14 (permalink) Old 12-28-2004, 01:08 PM
larryg, any input?
You should confirm with a voltmeter which wire has a steady 12v with the key on but the engine not running (wires disconnected from the coil). That wire is battery voltage and the other wire triggers the coil firing and will be the one you want.
I would need to see a wiring diagram as well as the Veypor instructions to be sure. It really depends on what kind of signal it is looking for. Are the Veypor instructions available online or can you send me a copy ([email protected])? I might be able to help you better that way.
post #10 of 14 (permalink) Old 12-28-2004, 02:44 PM Thread Starter
post #11 of 14 (permalink) Old 12-28-2004, 07:08 PM Thread Starter
Okay, I got it working. Apparently I DID choose the correct wire, I just had to adjust the Veypor. Now it reads accurately.
post #12 of 14 (permalink) Old 12-29-2004, 12:11 AM
Congrats! It would have been a shame if you had to break out some of that TNT
post #13 of 14 (permalink) Old 12-29-2004, 08:15 AM Thread Starter
lol, I about ready to do that! I'm wondering now, if it even matters which of the wires to use? I'm not going to redo it since it's working now, though.
post #14 of 14 (permalink) Old 12-29-2004, 01:02 PM
Usually, either wire will work but sometimes you need a stronger signal. The way the coil is wired, the signal wire closes the circuit to ground causing the coil to fire. This shows as a pulse on the voltage wire as well and most components can see that on either one.
